japan MAX
- Joined
- Oct 11, 2024
- Messages
- 3
- Likes
- 0
I live in Japan.
Last month, the price dropped to 165,000 yen, so I bought the SA30.
When playing music on the SA30 alone via streaming, the sound quality was very high and the bass was powerful, which was a good impression.
However, when playing music on the MUISIC LIFE/AMAZON MUSIC app, songs skipped and I couldn't play it stably.
So I tried a few different methods.
The best way to do it was to output analog from the EVERSOLO/A6ME, turn on analog direct mode, and bypass the DSP.
The sound pressure was about 5db higher than in normal mode.
I also listened in analog direct mode after turning on the processor mode and fixing the volume, but this is a format where the volume is controlled on the preamplifier.
However, if you restart the power with analog direct mode on, the display remains the same, but it seems that the settings are reset.
I checked with the manufacturer's support, and they told me that this was due to the specifications and asked me to return the product.
The quality of the SA30's amplifier is good, but the software is low quality and there are no plans to update it, so I'm considering whether to keep using it or return it.
Please share if you have the same problem.
The version is 1542.
