I am really disappointed. You made such a nice two parts and promised the third one but...still nothing. Did you abandon it?Part 3 is almost said in the room EQ reviews I have been doing and to some extent the speaker reviews (listening test part).
Yes, it’s been abandoned. However once you get started with REW and learn what target curve you like, you already have all the tools you need. You’re just going to have to make a ton of errors before reaching the promised land.I am really disappointed. You made such a nice two parts and promised the third one but...still nothing. Did you abandon it?
I am in process of learning of room acoustics, especially measuring but didn't find beter article than your one so I really miss Part 3.
In a word, no. The microphones are of unknown type and quality. You need omni capsules that are quite flat in the frequency range. The capsules on the pictured item are cardioid capsules with falling bass response. Even if you had omni capsules for it, they are likely unsuitable, but might be worth trying below 5KHz.I currently have access to a Zoom h5 recorder. Would it be sufficient to capture measurements to improve the sound of an otherwise untreated setup?
Umik1 is relatively cheap and highly regarded.Thanks for your response. That's a shame but I'll see if I can find a more suitable mic in that case
The ECM8000 is variable like a lot of those mics (the UMIK-1 is the same). I have 2 of them and I had them characterised last year by a friend in a national testing lab - you can easily see the difference between 2 samples. I am only confident using these because I have had them measured. They are quite stable over time.Hello amirim and friends,
Just for your reference, I use measurement microphone BEHRINGER ECM8000 with CEntrance MicPort Pro USB (48V phantom PS capable on 5V USB) for REW measurements in my multichannel multi-driver multi-amplifier project. I think this combination would be one of the de facto standards for fundamental sound measurements.
Hello PaulD,
Thank you for your kind follow-up.
Yes, I know the variation; for accurate precise measurement, therefore, we need to first calibrate individual ECM8000 (and other measurement microphones), and the calibration data file can be loaded into REW.
Yes, I probably should have pointed out that my graph goes +/- 3dB... So in the scheme of things these mics are perfectly suitable for EQing issues below about 5kHz, where most of the issues lie. People should not be put off by a circa 1-2dB variation in the lower range - room modes are MUCH worse than that!Hello PaulD,
I did and sent you a notification. Your welcomeWhom ever edited my post, thank you! Your very kind.
