Got it! And thanks. Part 1 and 2 cover the most of it now I discover. Just don’t get trapped in the SPL hole! Otherwise I took a couple samples of one speaker to test. It’s working. Lol. Thanks all
That’s actually a really good question. I’m sure you could prob use that mic.. or even the umik. But, the question I guess is are those mics sensitive enough for it. Look into IMM-6. I saw that quickly.. maybe that would be a good one!? Would really need to be a quiet room! Ha ha great question tho!Hello.
To measure the room I am clear about which mic to choose, but what mic do you use to measure the response in headphones?
Is it a good idea to use the tuned Audyssey mic?
Obviously not scientific at all, just to play a bit at home.
Regards!!!
The downside of this mic is that it is designed for mobile devices. I mean for REW and Headphones...... Look into IMM-6. I saw that quickly.. maybe that would be a good one!? Would really need to be a quiet room! Ha ha great question tho!
I found this!!:
https://www.audiosciencereview.com/forum/index.php?threads/audyssey-microphone-with-rew.14086/
Hey look what I found.
https://www.minidsp.com/products/acoustic-measurement/ears-headphone-jig
Would that work for you.
Followed this tutorial from Roon Community - - > https://community.roonlabs.com/t/a-guide-how-to-do-room-correction-and-use-it-in-roon/23800
1. Measured Left speaker (LS)
2. Measured Right speaker (RS)
3. Pressed EQ having focus on LS
4. In the equalizer window selected:
4a. “Var smoothing” from options
4b. Selected “Generic” equalizer
4c. Selected “None” as speaker
4d. Pressed “Set target level” text
4e. Finally pressed “Match response to target”
5. Repeated steps 3 - 4e for RS.
6. In REW's main window, selected menu “File -> Export -> Export filter impulse response as wav”.
7. In Roon:
7a. Settings - Audio - Select Device – DSP Engine – Convolution - Load Wav-file created in step 6.
Result: Extremely distorted sound ... :-(
My soundbar has room eq (Sonos ARC)….how would you use REW on a soundbar could you take your measurements by casting windows to your smart tv?
Geweldig dit forum, er staat zoveel onzin op youtube... but does anyone know where I can find the 3rd and 4th part of the REW explanation
Skip those measurements.Where do you put the microphone, with Dirac, on the "back" positions when the seat is a sofa against a wall?. Already the main listening position is barely 45 centimeters from the wall, the minimum distance from a wall required by Dirac.
In the first measure, the most important, the mike has to be between your ears, so you can not be there, right?. But you want to be there and your body will be reflecting sounds, right? The other measures have to be run under similar conditions. Nevertheless, pay way more attention to setting up the speakers volume and specially the sub/sGeneral question about measuring, I hope this is the right place to post this question.
All the advice about measuring suggests leaving the room when the measurement is being taken (apart from moving microphone about method obvs). I get that the signals can be loud, but I always listen to my music with a great lump of meat in between the speakers i.e. me. Surely this will have a substantial effect on the measured response?
Hi Dennis,
