Veri
- Joined
- Feb 6, 2018
- Messages
- 9,667
- Likes
- 12,300
Here linearity eventually falls apart though, on the DX3 it's "just" noiseGo Apple! Vastly better linearity than the DX3 Pro.![]()
It might be interesting to compare both of Apple’s $9 dongles.... this review is USB-C to 3.5mm (from a Windows PC), there’s also Lightning to 3.5mm (from a recent iPhone)
He mentioned the volume issue in the initial post when testing with his Samsung S8+.@amirm Do you have an Android phone with USB-C you can test this with? I've read that Android phones only recognize one sample rate on the built in driver and that the volume was quite low. Folks were unsuccessful at having any applications with a built in bit-perfect driver properly recognize the Apple dongle.
Now please forgive me as I go drown out my sorrows as an ex-Microsoft guy having to recommend an Apple product....
This review further confirms the idea I tried to convey to users here --- laptop / phones / dongles today are so good that you don't even need a DAC/amp. This is especially true if you're using Apple's products (iPhone, Macbook Pro). In measurements those $1000 DACs may perform better, but your ear is not good enough to tell the difference in a blind test.
Also bear in mind these dongles have ADC feature as well.
The E10k just got upgraded to the K3 which I'm sure will be no slouch. An all-in-one is always handy in terms of footprint on your desk.Would pairing this with JDS Atom better than most dac/amp combo such as E10k, DFB etc?
I have not. Is there a free one to try? Don't feel like spending money on USB Audio Player right now.Have you tried it on Android with an different app?
It only has 1 volt output instead of usual 2 volts. So your gains on the amp will go down and won't be able to achieve maximum power on Atom.Would pairing this with JDS Atom better than most dac/amp combo such as E10k, DFB etc?
Unless you can show me how I can get that one to run on Windows, it will be a pain to test.It might be interesting to compare both of Apple’s $9 dongles.... this review is USB-C to 3.5mm (from a Windows PC), there’s also Lightning to 3.5mm (from a recent iPhone)
Indeed. I was just having lunch with a Microsoft person and he was explaining the same to me.I know you are being tongue in cheek but I do a lot of work with Microsoft and they are long over any issues with other technologies. I think it's a key reason for their massive success of late. There are more Linux servers in Azure than Windows and I just installed the latest version of Visual Studio for Macintosh yesterday
It would be fully destructive as I have to cut it open and likely damage it. So let's wait to make sure there are no other questions and then I might explore that.Teardown? Please....?
Good deal. I was not looking forward to doing this.Or just see if someone else has done it - https://www.cabledo.com/apple-usb-c-digital-to-3-5-mm-headphone-adapter-teardown/
Just sayin'...
I have not. Is there a free one to try? Don't feel like spending money on USB Audio Player right now.![]()
It really should be the exact same dac/amp chip inside both Apple convertors.Unless you can show me how I can get that one to run on Windows, it will be a pain to test.
