Review and Measurements of Yamaha WXA-50 Streaming Amp
BitPerfect_
Please don't confuse the App version (which is indeed 4.50) with Firmware version or System version which is 2.86 (1925).
@SS55 you can check the Firmware version in Settings, Room Settings, Information, System version.
Did you tried to restart the device in Settings, Room Settings, Reboot?
Shut down the device, unplug it for a few minutes then reconnect to power supply, restart and see how it goes. Good luck!
SS55
I tried everything you mentioned. The update was 90% complete and failed but it seems to be the latest version.
BitPerfect_
2.86 (1925) it’s the latest as far as I know, I’ve updated yesterday successfully and that’s the version. Maybe someone could confirm.
If failed but still appear, maybe you can download and install a previous version and after that update to the latest? just saying in order to avoid malfunctions … but better get in touch with Yamaha and see how they advise. There is a chance to brick the unit.
BitPerfect_
Hmm… then that’s strange. I’ve asked Yamaha. I’ll be back with details. 2.70 was in August and maybe 3.0 is for other products. We will see.
LE: @SS55 v2.86 confirmed by Yamaha support, the latest Firmware version for WXC, WXA-50.
Gyosa1
all 3 of mine just updated successfully.
anyone know what this version does ?
it’s not on the Yamaha website yet ..
bk
BitPerfect_
According to Yamaha support reply, this firmware update 2.86 includes
  1. SiriusXM playback stability improvement (U.S.A. and Canada only)
  2. Spotify connection stability improvement
Gyosa1
Thank god !
about time on the SiriusXM fix !
took long enough….
all summer mine would constantly disconnect from SiriusXM and then refuse to reconnect unless multiple reboots were performed or signing out of SiriusXM and re-signing in. Then it would work fine from anywhere from a minute or two to an hour or two … then randomly disconnect again . Repeat entire process again.
it was essentially “broken” - and , yes, it even happened on the one I have connected via Ethernet cable direct to the router. Tidal would work just fine , so I knew it wasn’t the WiFi signal. I had basically given up on it .
they had the exact same issue a couple years ago and it took Yamaha forever to fix it.
according to the Yamaha rep I spoke to back then , SiriusXM changes their codec from time to time and Yamaha is very slow to respond .
was about to replace it with something else…. Dunno with what , it’s the only SiriusXM streamer I know of…..
maddening when laying in the pool trying to relax to music.
bk
gags11
My Yamaha CX-5100 processor also updated to ver 2.86 successfully days ago.
sethr
Does anybody know if it prefers 44 or 48Khz SPDIF input? Also curious about whether I should be using 24 or 32 bit depth (I assume 24)... thanks!
BitPerfect_
If you’re referring at RCA Coax, there is no input, output only. There is indeed a digital input, but it’s optical.
coastpunk
Can anyone please confirm if the WXA-50’s EQ settings also affect playback via the analog and optical inputs, or if the settings only affect the streaming (network) audio playback? This YouTube video seems to suggest the latter.
I’d like to tweak bass, mids and treble but will only be using the analog (aux) input. Thanks!
GiBo61
Is the level of the analog outputs of the Yamaha's WXC-50 pre-amp high enough to feed a Class D amplifier based on either Hypex NC252MP or Hypex NC502MP?
batfunk
You need at least 2 Vrms to feed Hypex amps at max power, so you're fine :)
dougi
ACT, Australia
TrexWasabi
If set up vertically, is there an issue with cooling if the volume knob is on the top? I.e. opposite to what the diagram in the manual shows?
pseudoid
I did many weeks of research before going with the WXC-50. I had a desktop Yamaha "Cavit" system made for a PC, before desktop/PC audio hardware became a contender. That darn thing is still getting use in the garage for FM/AuxIn and AudioEngine transmit to the desktop/PC. I HAD no choice when I realized that old Yamaha was designed very well, and thus pull the trigger on the WXC-50. I just plugged it in and made a few quick connection (TOSLINK, Aux IN, LAN, USB) and turned it on w/o RTFM. After a few months of basic usage, I had time to dig in and learn about MusicCast and all the features under the hood that it offers. Previously someone had posted trick with logging in using ip address followed by /setup in a browser address window.
Here is another I found:
As the IP address of this unit appears on the address
bar, enter “/service_info” following the IP address and
press the [Enter] key.
Then, “Device Information” will appear.
