AndrewDavis
- Joined
- Apr 4, 2019
- Messages
- 220
- Likes
- 431
Like taking off a pen cap and putting it again in place.
Yep.
Check aliexpress, they've got tons of sellers selling this exact knob. The cheapest one I've found a week ago was https://www.aliexpress.com/item/33008675021.html?spm=a2g0o.cart.0.0.7c363c00nPTrHY&mp=1 but price might have changed.
Didn't think it would be able to drive my diy F5 amp, but it's loud already at 50% through Volumio. Would you still recommend a preamp?
Anyone else having trouble with the Khadas Tone Board after Windows update 1903? I tried windows drivers and the Theyscon (very old V2 ones) but no luck.
DPC Latency checker gives me red spikes. But also without the spikes when start playing audio everytime it will pop first before playing. Settings the sample rate to 384K smoothens this out. But TBH I never had these issues before and I had to go back to my DX3 Pro (running with the latest Theyscon V4.67 drivers picked from their D50s that install and work flawlessly.
https://www.techpowerup.com/258611/...io-stutter-bug-microsoft-hasnt-managed-to-fix
This is the bug I'm talking about. It seems different per device.
Anyone else?
Anyone else?
Not the RAM, I went through practically every trick on the internet to get rid of it. It doesn't matter all stutters... The driver needs to be update for Windows 1903 and up. I emailed Theyscon with the info but not sure what will happen maybe we should contact Khadas also. As of now it's a shitshow. My Khadas is unusable on Windows. I'm back at the DX3 Pro for desktop use. Which is not a punishment but it's missing that bass oompf and clarity for gaming. It's more suitable for music.
Hope they can get it sorted soon.
My DX3 Pro works flawless with SPDIF and USB it seems.
You might want to post your Windows 10 drivers issues on the Khadas forums. Maybe someone has a workaround (or you may have to rollback the 1903 patch).
Khadas Tech Support Forum
Khadas Tone Board Forum
Given that other devices are affected and that not all installations of 1903 are affected I feel like the issue is probably on Microsoft's side. For what it's worth I appear to be running firmware version 4.11.0 and hardware version 1.04...
Yes that's the driver. My DX3 Pro uses the EXACT same driver by default and it works without pops and crackles.
I think the Khadas needs a firmware update to be compatible with Windows 1903 and up again.
Now hope its alright correct your post a bit in below
Here is the S/PDIF input performance. You activate it by just hooking up a USB power supply to USB port. I used the little switcher Wesion sent me.
With USB input, Channel 2 had some spikes around 10 kHz which are now gone, resulting in nearly 2 dB improvement.
