@Transpareo in systray bar should be a red T, that would be Thesycon applet you might want to use for this. Also, I guess Windows > Control Panel > Sounds could do the same...just give it a try.
Yes, they have removed the virused file. The answer they got was in English for me, so I was OK with that.So it is safe to update again?
Yeah, I think so.So it is safe to update again?
36 EUR for the case shipped to Canada. Ouch
21 EUR delivered in France.
Ordered one. I hope I won't have a problem with the crooked USB input and the case.
How about you confirm it by removing the Topping D10 and testing it out?I've been using the TB with spdif input and powering it with usb power using my 5V cell phone charger or the usb bus power from my mobo, though, my topping D10 is comes before my TB in my audio chain and have the D10 selected as default audio device in windows. Perhaps someone can confirm your question... o.o
Hi everybody, I'm interested in buying the TB but I don’t understand if the TB is capable of autoswitching (SPDIF<->USB) or not .
As far as I understand if the TB is connected to a PC then the SPDIF cannot be used, even if the PC is used only to power the TB and is not playing audio. Is this true? Do I have to disconnect the PC and connect a simple power adapter in order to use the SPDIF input? Thanks!
TB is connected to pc for usb power and spdif input from D10. The TB isn't on the list for selectable audio devices so my guess is yes, the spdif input cancels out the usb audio input.
You do realize how does this work? If you have for example a realtek integrated dac on motherboard and want to use the SPDIF from the realtek chip, you would connect the realtek spdif output port on the back of your PC to your Khadas Tone Board into the KTB SPDIF input, after this you may connect it to an AMP via RCA cables and then to your headphones via 1/4", 1/8" or even XLR connector.TB is connected to pc for usb power and spdif input from D10. The TB isn't on the list for selectable audio devices so my guess is yes, the spdif input cancels out the usb audio input.
