- Thread Starter
- #561
So difficult to fathom that kind of interference. Very strange.
Update on my issue with the D10 malfunctioning when turning off amp:
As I mentioned previously the D10 sometimes malfunctions (relay clicks, sometimes crashes) when I turn off my headphone amp or speaker receiver. At first I thought there was current going back into the RCA output from the receiver but it seems that even if they aren't connected in any way to the D10 it still happens. So I guess it's not coming from the RCA output but from the USB. Since I have everything connected to the same power strip, this is most probably current/noise coming from the receiver -> computer -> USB connection -> D10.
I'll try connecting the the computer and the amp to separate power outlets to see if it fixes it.
Question: When I played a standard PCM file while still using "DSD : ASIO : Topping Audio Device" it played fine and display showed proper PCM sampling rate. Is there any reason not to use this setting then when playing PCM files?
I have never detected any difference in SQ when using DSD: ASIO or DSD: WASAPI to playback PCM.
How are you controlling volume when playing DSD?
I think this is normal for DSD.
Thanks. There is a way to access the internal volume control of the D10 using Volumino. I have wondered if this could be done with JRiver or even if it works on DSD with Volumino. Currently, I convert DSD to PCM @352.8 for easy volume control and use of DSP's. I doubt there is any SQ improvement sending DSD to the DAC.I always use my preamps volume control. I tried the slider in Foobar and it makes no change when playing DSD. I also tried in the Topping Control panel under Volume tab and those controls mute audio as soon as you adjust them below 100%. I think this is normal for DSD.
Volume control of D10 can be controlled with Jriver.I have wondered if this could be done with JRiver
It doesn't. Controlling volume of DSD is tricky.or even if it works on DSD with Volumino.
I do the same and to me it sounds the same as DSD.Currently, I convert DSD to PCM @352.8 for easy volume control.
Great job. I managed to reproduce that and instrument it.For those experiencing resets and lock ups with the D10 I may have found a way for Amir to test it.
I normally run my D10 with an O2 amp on battery. Today I happened to have plugged into the wall wart. I can reliably reset the D10 and make it cycle the relay by simply pulling the AC adapter out of the socket with the O2 in off position.
The trick is to make sure you have the O2 on at least once before you pull the adapter. I’m assuming there is some residual capacitance that is discharged when you pull the plug and it is large enough to reset or lock up the D10.
Since he is currently reviewing the O2 perhaps he could put a scope on it and let us know what happens when you plug and unplug the AC adapter on the output.
Here is what the O2 is *backfeeding* into its input when you pull out the power supply:
The worst case spike is a little hard to see but I put the cursor on it (dashed horizontal lines) and it 16 volts!!! The amount changes from run to run but it is always many volts.
Given this, the fault is in the O2. The output of the DAC should have not transients fed back to it. This is likely feeding into the power supply rails of the Topping D10, causing the processor to get screwed up. Yes, that is a technical term.
I guess Topping could put mitigation for this also but seems to me this is an O2 problem.
Not likely. It is an analog, electrical problem.Would Topping be able to fix this issue with a firmware update?
I am a bit concerned about the amplifier feedback issue. Two members have reported it with different headphone amps. I might go for a D30 just because of stability.
