Review and Measurements of Okto DAC8 8Ch DAC & Amp
Snoozer
dmesg -> the last two messages appear after trying to play actually something in Volumio, which is very similar to the same type of error I get with HQPlayer embedded (bootable) and also in Audiolinux
Code:
[46144.518557] usb 1-1.3: New USB device found, idVendor=20b1, idProduct=2009, bcdDevice= 1.20
[46144.518564] usb 1-1.3: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[46144.518570] usb 1-1.3: Product: DAC8PRO
[46144.518575] usb 1-1.3: Manufacturer: OKTO RESEARCH
[46144.518579] usb 1-1.3: SerialNumber: 000060
[46144.616850] usb 1-1.3: 1:3 : unsupported format bits 0x100000000
[46144.673320] input: OKTO RESEARCH DAC8PRO as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.4/0003:20B1:2009.0002/input/input1
[46144.738037] hid-generic 0003:20B1:2009.0002: input,hidraw0: USB HID v1.10 Device [OKTO RESEARCH DAC8PRO] on usb-0000:01:00.0-1.3/input4
[46153.506647] usb 1-1.3: USB disconnect, device number 4
[46186.038794] usb 1-1.3: new high-speed USB device number 5 using xhci_hcd
[46186.169493] usb 1-1.3: New USB device found, idVendor=20b1, idProduct=2009, bcdDevice= 1.20
[46186.169500] usb 1-1.3: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[46186.169505] usb 1-1.3: Product: DAC8PRO
[46186.169511] usb 1-1.3: Manufacturer: OKTO RESEARCH
[46186.169516] usb 1-1.3: SerialNumber: 000060
[46186.284972] usb 1-1.3: 1:3 : unsupported format bits 0x100000000
[46186.341272] input: OKTO RESEARCH DAC8PRO as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.4/0003:20B1:2009.0003/input/input2
[46186.408956] hid-generic 0003:20B1:2009.0003: input,hidraw0: USB HID v1.10 Device [OKTO RESEARCH DAC8PRO] on usb-0000:01:00.0-1.3/input4
[48182.283416] usb 1-1.3: 1:1: usb_set_interface failed (-110)
[48182.959167] usb 1-1.3: 1:1: usb_set_interface failed (-71)
Snoozer
Can you also post aplay -L (note capital L) ?
noted, srry about that
aplay -L
Code:
volumio@volumio:~$ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
pulse
    PulseAudio Sound Server
default:CARD=ALSA
    bcm2835 ALSA, bcm2835 ALSA
    Default Audio Device
sysdefault:CARD=ALSA
dmix:CARD=ALSA,DEV=0
    Direct sample mixing device
dmix:CARD=ALSA,DEV=1
    bcm2835 ALSA, bcm2835 IEC958/HDMI
dmix:CARD=ALSA,DEV=2
    bcm2835 ALSA, bcm2835 IEC958/HDMI1
dsnoop:CARD=ALSA,DEV=0
    Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1
dsnoop:CARD=ALSA,DEV=2
hw:CARD=ALSA,DEV=0
    Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=2
plughw:CARD=ALSA,DEV=0
    Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=2
default:CARD=Headphones
    bcm2835 Headphones, bcm2835 Headphones
sysdefault:CARD=Headphones
dmix:CARD=Headphones,DEV=0
dsnoop:CARD=Headphones,DEV=0
hw:CARD=Headphones,DEV=0
plughw:CARD=Headphones,DEV=0
default:CARD=DAC8PRO
    DAC8PRO, USB Audio
sysdefault:CARD=DAC8PRO
    DAC8PRO, USB Audio
front:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
    Front speakers
surround21:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
    4.0 Surround output to Front and Rear speakers
surround41:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
dsnoop:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
hw:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
plughw:CARD=DAC8PRO,DEV=0
    DAC8PRO, USB Audio
Snoozer
wow, that is something man !! Thank you very much for your help, really appreciate it
wineds
Melbourne, Australia
Ok I was wrong sorry. The UI only lets you select USB : DAC08PRO. But that option works fine for me. Tested using radio playback and that works fine. In PiCorePlayer you have to select plughw:CARD=DAC8PRO,DEV=0. Edit : Are you using the supplied USB cable? I was using one I had in the cupboard for a while and that caused all sorts of instability like you are seeing. Maybe also try pulling the power cord to restart the DAC08PRO.
Snoozer
Thank you wineds , I have setup properly volumio so the problem is definitely not there.
Could you please post your dmesg ?
Snoozer
This is what I get when I try to aplay a simple wav music file:
Code:
volumio@volumio:~$ aplay -v Gottschalk.wav -D surround71:DAC8PRO,0
Playing WAVE 'Gottschalk.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
aplay: set_params:1297: Unable to install hw params:
ACCESS:  RW_INTERLEAVED
FORMAT:  S16_LE
SUBFORMAT:  STD
SAMPLE_BITS: 16
FRAME_BITS: 32
CHANNELS: 2
RATE: 44100
PERIOD_TIME: (125011 125012)
PERIOD_SIZE: 5513
PERIOD_BYTES: 22052
PERIODS: (3 4)
BUFFER_TIME: 500000
BUFFER_SIZE: 22050
BUFFER_BYTES: 88200
TICK_TIME: 0
wineds
[ 2.540683] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.540697] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.540710] usb 1-1: Product: USB2.0 Hub
[ 2.542729] hub 1-1:1.0: USB hub found
[ 2.543069] hub 1-1:1.0: 4 ports detected
[ 2.868058] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
[ 2.999067] usb 1-1.1: New USB device found, idVendor=20b1, idProduct=2009, bcdDevice= 1.10
[ 2.999082] usb 1-1.1: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[ 2.999094] usb 1-1.1: Product: DAC8PRO
[ 2.999106] usb 1-1.1: Manufacturer: Okto Research
[ 2.999117] usb 1-1.1: SerialNumber: 000014
[ 3.004130] input: Okto Research DAC8PRO as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00: 00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.4/0003:20B1:2009.0001/input/input0
[ 3.068309] hid-generic 0003:20B1:2009.0001: input,hidraw0: USB HID v1.10 Device [Okto Research DAC 8PRO] on usb-0000:01:00.0-1.1/input4
[ 13.243733] random: crng init done
[ 105.659463] initramfs: Factory image created
[ 105.659592] initramfs: Creating archive for factory kernel...
Snoozer
thank you !! the following is my lsusb ... can you post yours too please ?
lsusb -v
Code:
volumio@volumio:~$ lsusb -v
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         3
  bMaxPacketSize0         9
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0003 3.0 root hub
  bcdDevice            4.19
  iManufacturer           3
  iProduct                2
  iSerial                 1
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           31
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
        bMaxBurst               0
Bus 001 Device 005: ID 20b1:2009 XMOS Ltd
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2 ?
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x20b1 XMOS Ltd
  idProduct          0x2009
  bcdDevice            1.20
  iManufacturer           1
  iProduct                3
  iSerial                 2
  bNumConfigurations      2
    bLength                 9
    bDescriptorType         2
    wTotalLength          463
    bNumInterfaces          5
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         3
      bFunctionClass          1 Audio
      bFunctionSubClass       0
      bFunctionProtocol      32
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      bInterfaceProtocol     32
      iInterface              3
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               2.00
        bCategory               8
        wTotalLength          125
        bmControl            0x00
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     10 (CLOCK_SOURCE)
        bClockID               41
        bmAttributes         0x03 Internal programmable Clock
        bmControls           0x07
          Clock Frequency Control (read/write)
          Clock Validity Control (read-only)
        bAssocTerminal          0
        iClockSource            9
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     11 (CLOCK_SELECTOR)
        bUnitID                40
        bNrInPins               1
        baCSourceID( 0)        41
        bmControls           0x03
          Clock Selector Control (read/write)
        iClockSelector          8
        bLength                17
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             2
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             8
        bmChannelConfig   0x00000000
        bmControls    0x0000
        iChannelNames          11
        iTerminal               6
        bLength                42
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                10
        bSourceID               2
        bmaControls( 0)      0x0000000f
          Mute Control (read/write)
          Volume Control (read/write)
        bmaControls( 1)      0x0000000f
        bmaControls( 2)      0x0000000f
        bmaControls( 3)      0x0000000f
        bmaControls( 4)      0x0000000f
        bmaControls( 5)      0x0000000f
        bmaControls( 6)      0x0000000f
        bmaControls( 7)      0x0000000f
        bmaControls( 8)      0x0000000f
        iFeature                0
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID            20
        wTerminalType      0x0301 Speaker
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             40
        bmControls         0x0000
        iTerminal               0
        bLength                17
        bDescriptorType        36
        bTerminalID             1
        wTerminalType      0x0201 Microphone
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             8
        bmControls    0x0000
        iChannelNames          19
        iTerminal               0
        bLength                12
        bDescriptorType        36
        bTerminalID            22
        bAssocTerminal          0
        bSourceID               1
        bCSourceID             40
        bmControls         0x0000
        iTerminal               7
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              4
      AudioStreaming Interface Descriptor:
        bLength                16
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
        bmFormats         0x00000001
          PCM
        bNrChannels             8
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x0320  1x 800 bytes
        bInterval               1
        AudioControl Endpoint Descriptor:
          bLength                 8
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x00
          bmControls           0x00
          bLockDelayUnits         2 Decoded PCM samples
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
      iInterface              4
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             8
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bSubslotSize            2
        bBitResolution         16
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0190  1x 400 bytes
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
      iInterface              4
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
        bmFormats         0x80000000
        bNrChannels             8
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              5
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              5
        bLength                16
        bDescriptorType        36
        bTerminalLink          22
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             8
        iChannelNames          19
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              5
        bLength                16
        bDescriptorType        36
        bTerminalLink          22
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             8
        iChannelNames          19
        bLength                 6
        bDescriptorType        36
        bSubslotSize            2
        bBitResolution         16
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass       254 Application Specific Interface
      bInterfaceSubClass      1 Device Firmware Update
      bInterfaceProtocol      1
      iInterface             10
      Device Firmware Upgrade Interface Descriptor:
        bLength                             9
        bDescriptorType                    33
        bmAttributes                        7
          Will Not Detach
          Manifestation Tolerant
          Upload Supported
          Download Supported
        wDetachTimeout                    250 milliseconds
        wTransferSize                      64 bytes
        bcdDFUVersion                   1.10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      0 No Subclass
      bInterfaceProtocol      0 None
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      33
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               8
    bLength                 9
    bDescriptorType         2
    wTotalLength          463
    bNumInterfaces          5
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         3
      bFunctionSubClass       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              3
        bLength                 9
        bDescriptorType        36
        bcdADC               2.00
        bCategory               8
        wTotalLength          125
        bmControl            0x00
        bLength                 8
        bDescriptorType        36
        bClockID               41
        bmControls           0x07
        bAssocTerminal          0
        iClockSource            9
        bLength                 8
        bDescriptorType        36
        bUnitID                40
        bNrInPins               1
        baCSourceID( 0)        41
        bmControls           0x03
        iClockSelector          8
        bLength                17
        bDescriptorType        36
        bTerminalID             2
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             8
        bmControls    0x0000
        iChannelNames          11
        iTerminal               6
        bLength                42
        bDescriptorType        36
        bUnitID                10
        bSourceID               2
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            20
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             40
        bmControls         0x0000
        iTerminal               0
        bLength                17
        bDescriptorType        36
        bTerminalID             1
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             8
        bmControls    0x0000
        iChannelNames          19
        iTerminal               0
        bLength                12
        bDescriptorType        36
        bTerminalID            22
        bAssocTerminal          0
        bSourceID               1
        bCSourceID             40
        bmControls         0x0000
        iTerminal               7
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              4
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             8
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
      iInterface              4
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             8
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bSubslotSize            2
        bBitResolution         16
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
      iInterface              4
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
        bNrChannels             8
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              5
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              5
        bLength                16
        bDescriptorType        36
        bTerminalLink          22
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             8
        iChannelNames          19
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              5
        bLength                16
        bDescriptorType        36
        bTerminalLink          22
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             8
        iChannelNames          19
        bLength                 6
        bDescriptorType        36
        bSubslotSize            2
        bBitResolution         16
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface             10
        bLength                             9
        bDescriptorType                    33
        bmAttributes                        7
          Will Not Detach
          Upload Supported
          Download Supported
        bcdDFUVersion                   1.10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               8
Bus 001 Device 002: ID 2109:3431
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x2109
  idProduct          0x3431
  bcdDevice            4.21
  iManufacturer           0
  iProduct                1
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idProduct          0x0002 2.0 root hub
  bcdDevice            4.19
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Snoozer
@wineds : What is your firmware revision ? Mine is firmware 1.34 and serial number #60
I suspect there is a firmware bug
@Pavel: could you please chime in and say if there is any new (or older) firmware revision that I could use ?
wineds
My dac display says 1.1. I'll get the lsusb for you soon as I have reverted to my DietPi distro.
Edit : lsusb attached
  • lsusb.txt
Snoozer
thank you wineds, which firmware revision you have ?. (it is visible in your front panel under "Status > Firmware revision"
Snoozer
yours and mine seems to differ on "bcdDevice" . I've got 1.20 and your is 1.10 . The rest, seems to be fairly the same
Snoozer
so as far as I undertand, you are able to address all 8 output channels within linux with your unit, right ?
