Review and Measurements of Okto DAC8 8Ch DAC & Amp
Just for me to understand as I have never used a RME unit. You mention an ADC, is that a separate box or the ADC in the RME? Is the SPDIF loop-back internal in the RME or did you connect SPDIF out to in, by cable on the RME. Or was the loop-back done in a separate box? If so, what was that?
I understand that SPDIF and AES are in principle the same save for the voltage level and one "control bit". The signal fed to the Okto was that SPDIF or AES and if SPDIF from the RME was is the same signal as the loop-back?
The RME is an interface with lots of analog and digital I/O, see here for more info -> https://archiv.rme-audio.de/en/products/fireface_800.php. A rough sketch of the hardware setup is shown below.
In this case I have the RME mixer set so that when I play to channel 1/2 it outputs to both the optical and coaxial SPDIF outputs. RME coaxial SPDIF output is AES compatible and is connected to the Okto via a coaxial to XLR cable to AES input 1-2. RME optical SPDIF output is routed to the RME optical input for use as a timing reference. Okto analog output 1 is routed to RME analog input 1 for use as the main measurement channel. In REW the left channel is used as the main measurement channel and the right channel is used as the timing reference.
Sorry for all the questions but since I'm mixing two different DAC's in the same system understanding why I got +2ms and you got 1,23ms is important in my system. I need to delay my other DAC's to compensate for the Okto latecy. And gain.
Important to note that the setup describe above was an attempt to quantify worst case absolute latency of the Okto. If I wanted to use the Okto in a system in conjunction with the RME analog output and wanted to determine relative latency between the Okto and RME analog outputs, I would have used the analog output of the RME as a timing reference, not the SPDIF output.
Can you please check levels also, ie what is the level out, at 100% volume, compared to input. Just a compare measure would be great. My finding of +5db sounds high.
I get 4.3 V from the Okto when fed a 0 dBFS sine at 100% volume.
A few questions for you. From your description you are sending an analog signal to the BSS, what specific hardware are you using to do this? I assume that this device also has an ADC that you are using for measurements? I assume your measurements are electrical, not acoustic via a microphone? What specific BSS DSP are you using?
Michael
Great.
Now even I understand. Thank you.
A bit puzzling as that is kind of the same as I did. I fed the BSS a digital MLS signal via SPDIF and from there the internal DAC's and also Okto digital AES signal from the BSS digital output card (can chose SPDIF or AES out). I then compared to the Okto analogue output to the analogue output from the BSS analogue output card = DAC. As the BSS always time all outputs I'm pretty sure that the digital out (to the Okto) and the analogue output from the BSS are in sync, hence the delta would be the latency of the Okto. Same as you. Kind of.
But as mentioned +2ms sounds high and your measurements are probably right. I need to figure out where my setup goes wrong.
Your setup should give very precise data with the carve out regarding any potential timing differences between Toslink and coax SPDIF in/out. Probably completely neglectable.
Good news.
I am feeding the BSS digital signal via SPDIF in, so there are no ADC in the signal path until the DAC's (8-channels) in the BSS and the Okto DAC (8-channels).
Not sure what 0 dbFS in being 4,3V out means in the form of attenuation, if any? Can you please elaborate? I'm reasonable good at acoustics & analogue but less so in the digital domain. :-)
If you compare the analogue output of the RME with the analogue of the Okto (AES in) using the same signal, is there a difference there?
Kind regards and thank you
//Robert
How are you doing this comparison? I assume you need a dual channel ADC somewhere to make this comparison, hence my question about the ADC.
Not sure what 0 dbFS in being 4,3V out means in the form of attenuation, if any? Can you please elaborate? I'm reasonable good at acoustics & analogue but less so in the digital domain. :)
This is the point that we've been trying to make to you. DACs have different maximum output levels, this does not mean that a particular DAC is attenuating a signal, just that the maximum output level is different.
My Okto has a maximum output level of 4.3 V, whether or not that level is higher or lower than the maximum output level of another device entirely depends on the maximum output level of the other device. The RME for example has 3 possible settings for maximum output level (+19 dBu, +13 dBu, +2 dBV). The Okto maximum level compared to the RME maximum level for each setting is shown below.
+19 dBu (6.90 V): 20 * log(4.30/6.90) = -4.1 dB
+13 dBu (3.46 V): 20 * log (4.30/3.46) = +1.9 dB
+2 dBV (1.26 V): 20 * log (4.30/1.26) = +10.7 dB
This is why I want to know the specific hardware you are using, so I can know what the maximum output level is.
Michael
Michael
@sebackman is using BSS BLU 800 DSP, with different AI/AO, DI/DO cards see attached image
The okto with its 4,3V 14,9dBu
and the BSS 6,9V 19dBu
So in theory it should be a 4,1dB difference
And
If the voltage is 4,2V as the data sheet on a standard okto the difference should be 4,3db
Hi dualzmak,
That is way above my pay-grade. I my case it is not that complicated as no USB is involved at all.
My system (aktive 3-way (LCR) & 2-way system (rear) 5.2 (+ 2 subbs) = 15 channels used) uses a buildable DSP system (BSS) with the option of analogue and/or digital input and/or output cards. Each card has four channels and one unit hold 4 cards (16 channels). The system can handle up to 128 channels in and out.
The BSS system comprises of a DSP core and user selectable input and/or output cards. Each physical unit can take 4 cards and can be expanded up to 128 channels with additional units/cards. I have two input cards with together 8 channels digital input, 4 analogue output cards, DAC's, (16 channels) of which I use 2 and 2 digital output cards (8 channels) that feed AES to the Okto (8 channel unit).
I feed my DSP unit 7.1 SPDIF 48kHz/24bit digital signal that goes into a sample-rate converter (in the DSP) and into the DSP system. The DSP does its magic in the digital domain (41 bits floating point) and sends 8-channels to 4x 4-channels DAC cards using the same clock (using only 2 cards = 8 channels analogue) and 2x 4-channels digital output cards using and embedding the same clock.
The analogue output from the DAC output cards (8 channels) feeds part of the system and the digital output cards feed the Okto for the rest of the system. The digital output cards can be set to SPDIF or AES and will carry the clock in the signal. The DSP is "smart" and will make sure that all outputs are in sync, ie add latency so all output regardless of SW or HW are in sync. The Okto receives 8-channel AES signal in and, as far as I can understand, picks up the clock from channel 1, which should give a system in clock sync.
What I need to do, as opposed to your system, is to compensate for the Okto latency (AES in to analogue out) compared to the DSP DAC's which are in timing sync with the digital out feeding the Okto.
-And to compensate for the fact that the Okto seem to have some attenuation on the output compared to the input.
Does that make sense?
Kind regards
//Rob
OK, I thank you so much for your detailed description (and you time for writing) of your sync approach in your audio signal chain.
Now I well understand you do have "exact and consistent" sync mechanism by using S/PDIF and/or AES/EBU all the way through in your signal chain which Pavel of OKTO recommends and prefers; it looks he is rather skeptical for sync by outer common clock (10 MHz?) distribution to multiple DAC's.
BTW, if it would be possible at your end, I (we?) would highly appreciate if you could prepare/share a schematic diagram (even hand-drawn diagram should be fine) of your total signal chain for my (our) at-a-glance observation and understanding on your wonderful audio system.
Hi dualzmak,
I do understand the gain issue and have discussed with member "beatelund", who is also very helpful. He also seem to come to +5db difference between the Okto and BSS, so that seems reasonable.
I have adopted you latency of 1.23ms and that sound good on a quick test. I need to figure out where my measurement went wrong.
Attached is a simplified description of the sound-part of my system. The pre-amp is just a "digital switch" and with the right parameters it outputs non-encrypted digital 7.1 spdif 24/48 (up to 96). No ADC's in the system except for the turntable.
I do have a HDMI to SPDIF unit that will be implemented the next few weeks and will provide un-compressed 7.1 digital decoded sound from Bluray and similar.
//Rob
Hi dualzmak,
//Rob
Thank you indeed for your kind follow-up with nice diagram for my (our) "at-a-glance" understanding!
If acceptable for you, I would highly appreciate and welcome your kind participation on my thread, having your signal path diagram (and hopefully photo of your system).;)
- Let's share diagrams (and photos) of our total physical audio system and the whole signal path, with a few words and/or links
Not in the report : for 44.1kHz material, software upsampling in Roon to 192kHz linear phase / slow roll-off proved to give a slightly better performance than the DAC8 internal upsampling (which is not a surprise).
Is this statement confirmed?
Do not have an October DAC8 to measure. I have used Pure Music playback software which includes a 64 bit software sample rate converter. It has higher precision than a hardware based converter.
Used with older interface with Room Perfect which ran everything at 96/24. Older chips, but it measured better when 96/24 was inputted. Data still ran through the asynchronous rate converter though.
Roon may include a similar software rate converter.
If possible it's always better to do it in software in a capable operating system OS rather than a hardware based (Sharc - miniDSP) or other limited chip based platform. Your computer has far more dithering capabilities than the DAC chip has. @fabriceo even offers the advice to do so in software in advance of the incredible new Okto firmware he's developed on the limited XMOS DSP to reduce the amount of processing power needed onboard and that, in doing so, would be more precise.
Is it possible to mute the XLR outs while using headphone outputs? At the moment I need to manually turn off active speakers if I want to use the headphone which is quite annoying as they are always on.
Yes, it's basically always on.
It's not particularly helpful but I similarly had to turn off my power amps to use solely headphones. Since then I use a headphone amplifier that has XLR input and use a Nobsound Little Bear MC3 XLR switcher to switch between power amp and headphone amp. You could use a switcher to essentially unplug the XLR ouputs in a marginally more convenient fashion but it's not elegant.
The headphone amp doesn't have much horsepower for power hungry, insensitive, headphones so this was more of a necessity in my case.
Hi. Somebody knows what has happened here?. After I unplgugged the Okto power and plugged again my computer can not connect with Okto via USB. It doesnt recognize it. Whats more the Okto's display looks strange ie you can see the backgound info from another setting.
Edit! I restarted the unit and computer a couple of times and USB works again. However the problem with the display remains.
I thought burn-in on the display appears gradually. It happened after turning it off and changing power outlets. Turning it on and off doesnt solve the problem.
Burn-in happens because the light output capability of the light emitting material reduces the longer it has been emitting. If the display spends a long time showing the same image, like the 'Play' arrow and the 'Pure AES' characters, then those pixels won't put out as much light as the surrounding ones as the display gets older. It's a physical process, not something that gets reset with a power cycle. This will show up as a 'shadow image' when a whole area is lit up, just as you show. There are some dim pixels in 'Display' too which makes me think burn-in rather than an intentional display image. I don't know what is most often shown on your display though, so my guess may be wrong.
You would be right but it appeared suddenly on both displays within minutes. Before both displays worked as intended. I thought for a moment that I pushed the displays in while holding the unit and sth broke. It is quite distracting and makes it difficult to read the data at some points.
The shadowed background image doesnt even cover the exact data. For example when I change to Pure AES I can still see the shadow in the background. I cant catch it on the photo. You can also see that on the left side of this shadowed readings there is a triangle???
IMO, this isn't an OLED issue.
I recall having had a similar (confused) display a day after a particularly heavy storm went thru.
(This was years ago, and the software was still a bit unsettled yet.)
Even though I have excellent line filters, occasionally things will 'glitch' - in fact I recently had a similarly odd disruption of my Oppo BR player, which messed with the channel levels and assignments...took me a while to figure out what had happened.
A 'factory' reset solved the Oppo issue, and I seem to recall having done something similar with the OktoDAC.
I'll dig thru my emails and see if I documented what I did - though it had to have been a either a full reset, or simply unplugging and leaving it that way for a while before plugging it back in and powering up.
I only had the issue a couple times (ie, less than 3), and it hasn't reoccurred since I upgraded to the latest software.
Oh, and a Venu360 I'd used for years was completely killed dead by a storm event of some kind...so it can happen.
