Yeah, aptx HD and LL when gaming to pair to a BTR5. Anyway I read that short USB cables aren't either recommended.
It's an OLED screen and the polymers used in these screens have a finite life and wear out. Lowering the brightness extends the life of polymers and makes the screen less likely to suffer burn in (i.e. some pixels being more worn out than others and retaining an image). I have my D50s display set to turn off automatically for this reason. I also suspect that the D50s has had the brightness to turned down to avoid the incidence of burn-in and customer returns.
Certainly, the D50s has changed from the white color of the D50 to the blue OLED display, and the visibility has deteriorated.Does anyone or did anyone have both the D50 and D50S? I just received a D50S to replace my D50 (as I wanted bluetooth and the remote) but the screen is of noticeably less quality on my D50S unit. Like I can see the glow around the "board" where the numbers and letters are (not sure what the correct term is). The brightness is also quite a bit dimmer with both on "auto".
I haven't read much of the thread but I'm wondering if others have this problem. If anyone's D50S doesn't have this problem, I'd like to know so I could send them in to be replaced.
View attachment 39852View attachment 39853
View attachment 39855View attachment 39854
There is an ultrasonic tone at 28 kHz when feeding it 20 K input that is at -80 dB or so, setting that limit.
I ordered a D50s and wanted to know if it will pair nicely with a Marantz PM8006.
Yes!The D50s has a line level output and the PM8006 has line level inputs. What is your concern? What they might look like together?
All DAC with regular analogue output (RCA) are compatible with any amplifier. With the lack of headphones output, the D50 is a DAC onlyYes!
I’m new to this and don’t know if some DACs are only for headphone usage or if all DACs can be used with integrated amplifiers and speakers.
Yes!
Im using a dragonfly RED connected to a Marantz PM8006. Will I notice any differences using the Topping D50s? Ive already ordered it.
All right, I see your point. I won't bother anymore.Yes, the Topping is much larger, has a display and comes with a remote.
