Sorry, I find this entire conversation rather amusing, more like a dog chasing his tale, getting nowhere. The amp in question was build for music not testing, in it current state needs to pass zero tests.
That doesn't mean testing isn't useful. I'm no expert and I've learned a lot from this thread, when
@restorer-john first complained about the low continuous power rating of the NC400 I thought that was unreasonable, because to me it doesn't make sense to test an amplifier's maximum power for hours and hours. As someone who cares about weight, size, power consumption and heat output of the things I'm buying, I don't want manufacturers including heatsink capacity for my amplifier to run at maximum 24/7, because it's a silly waste of my money and my space. I'm not a person who is ever going to want to buy those insane 100lb+ amplifiers
However, after reading more and realizing that the FTC test is only 5 minutes, which Hypex themselves even have a defined rating for(!), I changed my mind. 5 minutes seems like a pretty reasonable standard for any piece of electronics to run flat out. Some kind of continuous testing is definitely relevant to real world usage, because it is entirely possible to overheat an amplifier with music. I've overheated my Denon X4000 running 4 ohm Magnepan 1.7s many times(with rock, unsurprisingly
). The receiver doesn't have a 4 ohm rating, so I knew that this was a risk and that it didn't have enough heatsink capacity for that usage. I dealt with it for a few years before eventually adding a more powerful amplifier(SDS-470C). If there was no standard for continuous testing, then Denon could simply say 'oh sure its fine into 4 ohms at max power....' without mentioning that that's for 30 seconds... or even less.
If
@amirm and other experts consider 5 minutes to be an unreasonable standard, that's totally fair... but then some standard should be set for reviews to be consistent. Whether it be 30 seconds or 1 minute or 3 minutes, I don't know, but if you don't test output for more than a second or two, I don't think that's actually sufficient.
