staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,016
- Likes
- 12,861
@gcompari
Here's every sample rate that the S G3 and 9038D supports:So if I get G3 I get also:
- 88.2, 176.4 (352.8?)
http://www.comtrue-inc.com/index.php/downloads2/category/4-ct7601drivers for Win 7, 8.x and 10
In my testing I found that both RAA and rtings consistently produced the best measurements and, subsequently, the best EQ presets for full-sized headphones.it's the only source I found for reliable measures about headphones
analog gain means a mechanical solution means a new and bigger housing and PCB, a potential point of failure, and an entry point for dust and moisture.you may sell 100x or more products if you add the analog gain control
again, no space inside the housing for cage-style shieldingA ferromagnetic metal case will better to stop EMI
with the S G3 and the 9038D sample that I'm currently testing there's absolutely no pause when changing sample rate in foobar Wasapi pushthe problem about the lose of many seconds at the start of tracks
