Review and Measurements of Benchmark DAC3
walt99
DFW
My 3B is silent but I think the latest SW update addressed the issue some folks were experiencing.
VERSION 1.1 (Production Release): Summary: • Version 1.1 improves the power management and provides a very slight reduction in standby power consumption. The improvement is so small that we do not recommend upgrading from 1.0 in order to “save power”. • In some cases, Version 1.1 can reduce the slight acoustic noise produced by the on-board DC/DC converters. This noise is inaudible in most applications, but in rare cases, some users have been able to hear some noise while the unit was off and in an extremely quiet room. This version can provide a solution for these rare cases.
Martini
I've often considered this a superb way to get your signal to your speakers (when using an AHB2 in the chain). Do you incorporate sub integration and/or DSP to correct for room modes? Would appreciate hearing your thoughts/experience.
I do have the AHB2 as well. A Mac Mini is used as the music server. I don't have a sub, as it's not needed, my speaker go deep enough. I do use the DIRAC-Standalone (Mac) software to handle room correction. It seems to work pretty well; better than what I would be willing to work to achieve with REW.
ex audiophile
Thanks, I hear you regarding working with REW. I suppose there is a windows version of Dirac, that would work for me. I use a Node 2i as source but it might be fun to try using a Windows setup. Happy Thanksgiving :)
Nkam
I just read this review for the first time and to be completely honest, from the aspect of science. Amir should delete the first page measurements from error as they can be misleading to someone who doesn’t have the time or patience to read through the entire thread, and to the accurate measurements listed far into the thread.
i mean we want to be scientific here I’m assuming.
so with a bit of editing the first measurements could be deleted and have a notation that the accurate measurements are on page X.
pablolie
bay area, ca
I have a DAC2HGC and it has some coil whine sound when its off.
Get the power supply replaced. Happened to mine as well. I sent it in to be fixed. Benchmark are good in support - I think it was around $200 to get the PS fixed and eliminate the high pitched noise. Should be completely silent.
Nkam
OK, the DAC3 HGC that Benchmark was kind enough to send arrived today. So I put it on the bench and ran a few tests. I will be on the road tomorrow late morning so if you want to have anything else measured (hopefully not!), ask right away.
NOTE: all measurements are using balanced output unless noted, with -10 dB jumper applied as the original review.
Let's start with our Dashboard view:
Right away we see a 2 dB or so improvement in SINAD/reduction of distortion compared to the loaner unit I had from @dallasjustice.
Let's look at the contested Jitter measurements using Benchmark's own ASIO driver:
We see a substantial improvement in jitter sidebands. We went from -108 dB or so to -131 dB!
No, it had nothing to do with using ASIO4ALL:
As you see, it makes no difference which driver is used. Both generate the identical, much improved results.
For completeness, let's run through the rest of our tests:
We see a marked improvement in low frequency noise/distortion (in green/brown). Gone is also the varying channel response that I saw (in red) in the first unit I tested. This matches our dashboard view of better THD+N/SINAD.
Here is IMD vs level and comparison to some other devices I had tested later, specifically Oppo UDP-205:
The Benchmark DAC3 HGC (in red) has substantially lower noise than all the other DACs I have tested. It starts to saturate a bit at maximum level where it then runs into Oppo UDP-205. But otherwise beats it handily.
And here is the spectrum of 1 kHz distortion and noise (saved for future reference):
Distortion products are well under -120 dB, satisfying our even most conservative standard for audibility or better said, lack thereof.
Finally, linearity:
Using balanced output (which is used in all of the tests above), the DAC3 nails the performance here. There is something you don't see in these graphs which is how much my analyzer struggles to get stable set of measurements. With every DAC I have tested, it usually times out and picks the last value at lower amplitudes. Not so with Benchmark DAC3. The results instantly converge allowing the analyzer to run through all the values. There is exceptional engineering here to generate such stability and precision at such low amplitudes.
Alas, the small blemish on unbalanced output remains.
Summary
This second loaner unit of Benchmark DAC3 (HGC) finally lives up to the standard and reputation of Benchmark as a company. Measurements are exceptional with no faults found anywhere. OK, there is a setback in linearity for unbalanced output but otherwise, this is as good it gets guys.
It is a puzzler as to why the previous loaner did not generate as exceptional of results as this unit. I hope Benchmark works with the owner of the other unit and investigates.
amir can you please explain to me the linearity measurement with the unbalanced where the line drops at around -100db?
does that dip downwards mean the highs roll off?
if it rose would it mean the top end would be higher in level a bit?
much obliged
Rosenbloom
London
My DAC3 just arrived this afternoon. My first impression is very, very good. Worth the money.
audiopile
  • Been using the DAC-3HGC for a few years -musta missed the plugs in headphone jacks issue ? Why would you do this ?
little-endian
Given that Amir's original posting in the review of the DAC3, while taking light differences between the DAC3 models into account, still mentions those side-band oddities and witnessed "less-than-expected" performance from Benchmark, I wonder what is the consensus now (on an academic level of course as even considering that some measurements would in fact be worse, it will hardly have any audible impact but rather a psychological).
John Siau from Benchmark argued that all bets would be off if one tried to measure something beyond the measuring equipment own capabilities as reference. Well, so far so much making sense, but whose measurements now weren't up for the task - Benchmark's or Amir's and how does this go along with unremarkable measurement results using the same methods here when testing other devices?
Also, all good now and we can rest assured that the DAC3 is as "flawless" as expected from such a pricey product or is it still "beaten" in a some aspects by some way more affordable products?
RichB
Massachusetts
I don't think we can rest assured that any product is as flawless as expected.
A second DAC3 measured better, and the DAC3 linear phase fast filter is well implemented, though I don't see it measured here.
- Rich
Nkam
- Rich
im , let me rephrase that for you
Benchmark sent a second one , which was measured correctly and the first one was sent to benchmark , where they did not find fault in it.
which means that either the first measurements were not done properly or there was a ghost in the machine that day.
Nkam
even the second measurements weren't correctly portrayed
in the picture attached we can see that the graph starts from +20db
and then the quote is to the point of , there was a substantial difference of jitter from -108db to -131db.
wheras the graph clearly shows that it should have read
we went from -128db to -151db.
either we are scientific or not.
