FurstMan
- Joined
- Feb 21, 2023
- Messages
- 21
- Likes
- 16
Hello music and science lovers,
I own a pair of Kef LS50 (Anniversary Edition) powered by a Cambridge CXA60, an Anti-mode 8033 Cinema DSPeaker and a subwoofer from a Boston Soundware XS kit :
Bass Reflex
Power: 100w RMS
Frequency response: 50 - 150 Hz
20.3 cm driver
Bandwidth: 60 to 180 Hz (24 dB / octave), low-pass filter
The latter has just broken down, so I need to find a replacement. For a budget of €500, I found the SVS SB-1000 (non-pro), which has even more interesting characteristics, capable of going much lower:
Close load
Power : 300w RMS (720W peak)
Frequency response: 24 - 260 Hz +/- 3 dB
30 cm driver
Variable low-pass filter (50 to 160 Hz + LFE)
My entire audio system is used in the near field, at a distance of around 1,2m.
Do you think that replacing my Boston subwoofer with the SVS will bring an audible improvement?
I know that room treatment plays an important role, and that low frequencies are highly dependent on it, but the advantage of a near-field configuration is to take advantage of the speakers' “direct” performance.
What's more, I intend to take advantage of the fact that it has a high-pass filter at 80khz to relieve the LS50s, which aren't the most comfortable in the low frequencies.
What do you think? Thanks in advance and have a nice day.
PS: sorry if I'm not clear, I'm a French speaker.
Bass Reflex
Power: 100w RMS
20.3 cm driver
Close load
30 cm driver
