I am currently trying to understand the reference levels of my audio interface. I use a Focusrite Scarlett 4i4 3rd gen, which has the following reference levels:
If I have understood correctly, these details always refer to the RMS value. I now want to check whether these details can be confirmed using a few simple measurements. For this, because it is easy to use, I have a sine wave at 1 kHz with an amplitude of 1 (i.e. 0 dBFS for the amplitude) and thus an RMS of -3 dBFS as a test signal.
If I now want to calculate which voltage value is present at the output of my sound card for such a signal and also the input level for a loopback setup, I would proceed as follows:
If I connect a balanced cable to my output and measure the signal with an oscilloscope, it should have a level of 15.5 dBu - 3 dBFS = 12.5 dBu (= 3.27 Vrms). If I now loopback the signal into the INST input, the reference voltage is at 12.5 dBu. That means - 12.5 dBu input voltage translates into 0 dBFS in digital domain. But when I do the testing I get -9 dBFS at my input.
| Output (balanced) | Line Input | Inst. Input |
| 15.5 dBu | 22 dBu | 12.5 dBu |
| 430 Ohm | 60 kOhm | 1.5 MOhm |
- So the first question is - what am I missing? Where does my math not fit? Can someone please give me a detailled example of the "way" from digital to analog and from analog back to digital domain?
- So the second question is - what am I missing again?
Why doesn't the levels differ by 6 dBFS?
