nanook
So EIN and max. undistorted input level plotted vs. gain would give the dynamic range vs. gain and represent the interesting parameter in the real world?
Both EIN and DR vs gain are interesting values, IMO.So EIN and max. undistorted input level plotted vs. gain would give the dynamic range vs. gain and represent the interesting parameter in the real world?
Yes I agree he is explaining the same thing. I prefer your chart to his. The point about this in regard to your post and AnalogSteph's posting is that you don't quite get the info you need with a simple number like only EIN or by testing with only a single input level or two. With the sensitivity chart and EIN vs gain you have what you need. If really splitting hairs you would also want SNR at 0 db gain.Actually, he's explaining the same I'm trying to explain.
And his bargraphs are similar to my sensitivity graphs, except he's just looking at the max gain value, and doesn't say anything about overall max value, which I also include.
This
Is the same than this
but without the left value (which I think is also interesting)
Found this on the maintenance manualThat Yamaha AD8HR must have a very funky gain structure for its curve to look like that. It almost looks like input amplifier gain is switched in ~12 dB steps (or perhaps it's actually an input attenuator? Almost makes more sense), followed by another stage with much finer ones. Quirky. The theory of it using an input attenuator would be supported by the fact that the (mic) input can accept levels up to +30 dBu when mic input amplifiers tend to have a minimum gain of 0 to +10 dB (I very much doubt that the unit would be running internal levels of +30 to +40 dBu). The noise penalty of this approach is quite obvious.
What I suggest is that we measure FS level (in dBu) and noise (in dBFS) for 4 gains:Yes I agree he is explaining the same thing. I prefer your chart to his. The point about this in regard to your post and AnalogSteph's posting is that you don't quite get the info you need with a simple number like only EIN or by testing with only a single input level or two. With the sensitivity chart and EIN vs gain you have what you need. If really splitting hairs you would also want SNR at 0 db gain.
So we are somewhat back to what is the simplest and fewest useful tests that Amir could perform when he tests interfaces or that we can do if we want to contribute useful information for others? I think the resulting info we need would be the sensitivity chart above and the chart of EIN vs gain setting.
You'll need to measure max input at 0 db gain. You might as well get the SNR or noise floor in dbFS while you are doing this.
You'll need to measure EIN at max gain and I think at least every 20 db below that.
So any criticisms or additions you think needed? Or something I'm missing?
Of course it looks like other than a few uncommon poor designs the makers of this gear have it pretty well covered. So perhaps to weed out only bad examples while giving less info Max gain at 0 db, EIN at max gain, and EIN at 30 db less than max gain will do about as well.
This will allow to choose a gain that is a good compromise between risk of overload and noise.What I suggest is that we measure FS level (in dBu) and noise (in dBDS) for 4 gains:
I agree, shorted will separate the really quiet ones from the good ones and the current noise contribution at 150 Ohm should be negligible for most input stages.I suggest we do it at least shorted and unweighted, since we can still deduct the 150 ohm load from theory.
In case the noise is mostly flat above a few kHz (that's my expectation), the A-weighting will make an almost fix difference in dB.I suggest we do it at least shorted and unweighted,
Well I can report what was measured. If you look at the screenshots the dba is to the right of the db level. In the case of this interface A-wtd is 2 db better. The other interfaces were in that range. 2.0 to 2.5 db. The difference didn't vary with gain level.Thanks, this measurement confirms my expectation that there may be an increase of the noise density towards lower frequencies, but that it's white in the audio band otherwise.
So we should even be ok when we measure un-weighted and give a calculated A-weighted value.
(or is my understanding wrong, that for a white noise distribution noise in dB vs. dBA differs by a fix number?)
There are less sensitive ones (like the Audix OM7 - an excellent mic - with 0.8mV/Pa), but what really makes the SM7b a challenge is that it's often used for spoken voice, and, even, from some distance (10-15cm).A Shure SM7b is about the least sensitive microphone you run across. Most modern ribbons are more sensitive. It puts out 1.12 mV at 94 dbSPL at 1 khz. Shure suggests you need 60 db of gain minimum to make it work.
Yes, but it is only about 3 db less sensitive than the SM7b. The ratio between it and 29 mV is only 32 db so not greatly different than 30 db between them. The fact OM 7s are typically held with hands wrapped around them very close to the mouth more than makes up for that 3 db.There are less sensitive ones (like the Audix OM7 - an excellent mic - with 0.8mV/Pa), but what really makes the SM7b a challenge is that it's often used for spoken voice, and, even, from some a distance (10-15cm).
The cumul of those conditions explains why it's considered such a critical mic.
You're right about sensitivity, but I'm pretty sure the range we need to cover is wider than that:A Shure SM7b is about the least sensitive microphone you run across. Most modern ribbons are more sensitive. It puts out 1.12 mV at 94 dbSPL at 1 khz. Shure suggests you need 60 db of gain minimum to make it work.
The more sensitive LDC microphones are 28 or 29 mV at 94 dbSPL at 1 khz. Let us call that a 30 to 1 ratio roughly. Which is also roughly 30 db vs an SM7b. So if we know how things work at max gain and 30 db less than max gain we have most microphones covered.
I suggested 1V above.Test #1
We need to test for max input at minimum gain. You can do that with a wide range of voltages. I suggest .775 volts as that is 0 dbu. You can read it straight off the dbFS graph to see what is the max dbu input level. That and the gain range is enough for this part.
Sure.Test #2
EIN with 150 ohm resistor at max gain and 30 db less than max gain.
SureTest #3
EIN at max gain with a short.
Yes, or AES-17 DR, which is probably better.(Do we need noise level at minimum gain with a short?)
I still think EIN for 4 or 5 gains makes more sense.Would anything be missing to tell us most of what we want to know for practical purposes?
That's the goal, indeedI'm hoping to make this simple enough Amir will do this when he tests audio interfaces.
If only one input is tested, it has to be the Mic input, without pad, I agree. That's clearGenerally speaking the majority of audio interfaces use the same microphone circuit padded down for line level. Amir already tests those for distortion, frequency response and dynamic range.
So what do you guys think? Will these three tests do the job?
@Rja4000 @AnalogSteph @nanook @KSTR @restorer-john @SIY
They will as long as you have a source impedance not much bigger than 150R. If you do, current noise that may be lost at 150R might be significant at, say, 50k.Test #1
Test #2
Are there mics with 50 k output impedance? Most common is 50 ohm to 200 ohm. I've seen a few at 300. I think I recall one at 600 ohms, and an old ribbon that was 1000 ohms.They will as long as you have a source impedance not much bigger than 150R. If you do, current noise that may be lost at 150R might be significant at, say, 50k.
Re: mic dynamic ranges, my 1cm diameter lab condenser mikes run as high as 50mV/Pa. My ribbon mikes are more like 2mV/Pa, as are my high-SPL 1/8" condenser mics, so there's a good 28dB spread right there.
I don't know, there may or may not be, but there's certainly guitar pickups like that, so there well could be some dynamic...Are there mics with 50 k output impedance? Most common is 50 ohm to 200 ohm.
There is wider range than 30 db between podcasting and drum overheads, but even with an SM7b or OM7 you won't be using maximum gain with drum overheads. Another common use is miking a guitar cabinet. Also you are not using max gain for those.You're right about sensitivity, but I'm pretty sure the range we need to cover is wider than that:
You also have to take into account the SPL of the signal reaching the mic membrane.
Between a SM7b used by a vlogger and a LDC used to record a nervous drum overheads (think RHCP), there is, in my opinion, more than 30dB.
But 0dBu or 4dBu also work.
Sure.
But then I'd go for 40dB rather than 30dB, and I'd rather chose a fixed FS voltage, like 100mV.
Sure
Than, load would be the AP's output impedance (which should be specified)
Lots of cheapie dynamics use 600 ohm capsules. That's about the highest you're commonly going to encounter, however, explaining why current noise tends to be a secondary concern unless you're leaving the input open. I have seen preceding pad circuits using resistors in the low kOhms though.Are there mics with 50 k output impedance? Most common is 50 ohm to 200 ohm. I've seen a few at 300. I think I recall one at 600 ohms, and an old ribbon that was 1000 ohms.
If the EIN spec is accurate gain must be about 55 db. You could loopback a signal you know and reduce it digitally by say -70 db and figure out the gain by running it thru at 0 and max gain.Ok,I did E-MU per your guide but can't find gain in specs:
Shorted
150 Ohm
Specs
