I seem to be having a hard time finding a simple circuit diagram of the improved crossover for the Minimus7. Not sure why. I find all sorts of discussion but no simple
image.
image.
image.
I still kinda miss Dogpile...Have you heard of Google? It's quite a good search engine. Much better than Ask Jeeves, the Webcrawler or Alta Vista. And get a new modem, 14.4k won't cut it anymore.![]()
I digitize the S/N 0402 sample and compared to one of mine:@MAB For reference, here's impedance sweeps of the two new old stock speakers from the photo above:
S/N 0492:
S/N 3375:
Mine are model 40-2030C, compared to your 2030A versions. Across model runs the matching is remarkable. And mine are definitely not NOS.Pretty good correlation for speakers 2883 units apart and produced 9 months apart. (March 1988 vs December 1988)
In the USA, I never had any hum problems with any Tandy/Radio Shack gear (from EQ's to the integrated amps & tuners).You're most likely right on the 4558 vs 5532.
The thing is sitting there, staring at me, so I might have a bit of poke around and see what I can do. I've got a second unit down at my father's place. I might test them both to get baseline numbers and see if my recollections are valid in 2024. I'm pretty sure I reverted one of them to double insulated decades ago due to hum. It's been a long time...
Plenty of RS (Tandy's) equalizers had the same problem- they earthed them poorly (random screw to the chassis) for Australia and created hum loop monsters from designs that were not made with a star ground/earth design or even a consideration of issues that would crop up when the device was actually inserted in a tape/pre in/out loop with other earthed gear.
That was the trick with R/S. They had monthly sales flyers. The minimus 7 (and its descendants), e.g., would be on sale once or twice a year at half-price, give or take. At half price, they were reasonable values. Not so much at full price ($79 @, give or take).In the USA, I never had any hum problems with any Tandy/Radio Shack gear (from EQ's to the integrated amps & tuners).
And, caught on sale, they were usually relatively good for the price.
) and, other than a visit here when they were moving house last year, have been in her family room with their TV since she got married (over) 15 years ago. Having noticed that the 1994 Optimus PRO 7 "specification" references a frequency "range" of 100 to 20k Hz , I thought it would be amusing to look back at the original, sealed box version as introduced in 1978.
From above:
1994: "Increased Bass" -- Response 100-20,000 Hz
source: https://www.radioshackcatalogs.com/flipbook/1978_radioshack_catalog.html
1978: "50 Hz bass". umm-hmm.
Some fuzzy maths.
Maybe that is the result of the "New Math" that they had been trying to teach in grade school in the late "60's".Having noticed that the 1994 Optimus PRO 7 "specification" references a frequency "range" of 100 to 20k Hz , I thought it would be amusing to look back at the original, sealed box version as introduced in 1978.
From above:
Some fuzzy maths.
I owned that Radio Shack sub for several years. 12" dual voice coil. The real crossover frequency was closer to about 200 or so, but OMG that was the most boomy bass sub/low frequency speaker I have EVER heard.Maybe that is the result of the "New Math" that they had been trying to teach in grade school in the late "60's".
That "New Math" might even be why I failed algebra when I was a High School sophomore but was able to use trigonometry at my job in real life (during my Senior year of high school).
Having learned to do things a bit differently in mathematics while in Austria (from my Austrian mother [to get to the same answer]), the teachers weren't happy with the way I showed my work when I was asked to do so. "You got the answer right but that's not the way you do it" was a typical response. And then they would attempt to teach (once again) me the "proper" way to do it, which only confused me.
In school, it also did not help to have undiagnosed (at the time) dyslexia (which seemed to affect me much more when dealing with numbers than with words).
But at work, I could visualize how something worked or needed to work (whether it was a plumbing run used in the building of apartments or the need to phase an array of antennas so that the power went more in a certain direction).
To put this back on track, I always used mine with a Radio Shack sub-woofer, which I believe was crossed over somewhere between 150-200 Hz.
The earlier one was a (walnut?) wood veneer that kinda' matched the wood Minimus 7's, the later sub-woofer was a much larger black veneer (oak?). Both were down firing 12" ones. I do not remember if the earlier one was ported (gave it to a friend) but the black ones are supposedly tuned to 29 Hz. I have a pair that I have modified that I currently use with a Pioneer car audio competition dual 4 ohm voice coil running in a 4 ohm circuit in each one.
The FR is 20-80Hz, and they are crossed over at 60 LF & 80HF. (with my Dahlquist M-905's handling above that.
As to the Minimus 7's, I still have several and use a walnut pair in my mother's (she is 90) home system with an ADVENT 300 receiver (she only plays LP's of listens to the radio.I owned that Radio Shack sub for several years. 12" dual voice coil. The real crossover frequency was closer to about 200 or so, but OMG that was the most boomy bass sub/low frequency speaker I have EVER heard.
The box was ported and obviously too small for the high Qts sub they used.
If was fun to use, but had a huge huge peak in the 50-90hz range, that added huge bass to just about any music, but often left it almost unbearable at times!
So i should have kept my late father's Minimus('s)?
The "Idea" and the looks of them are honestly better than the reality of them.So i should have kept my late father's Minimus('s)???
