Lads, with the suggestions of some members here, I got myself a UMIK mic and REW software. I have watched a couple of videos on how to get around measuring my speakers' frequency response. I have gone on to do this mainly to determine the extent of damage done to my drivers from an amplifier failure. The mid-bass drivers(the one in the Left speaker is more pronounced) produce a scratchy, distorted sound when recordings with instruments like double bass or cello are played. After what happened, the tweeter and the woofer sounded normal, but the ears could only pick up so much. The good lads here suggested that I pick up a mic and get some measurements done to determine where things stand and I have done so. Kindly excuse me for not being able to be more precise with the technical details. This is my very first attempt. I am no Amir or Erin(learnt so much from these two top fellas). I would appreciate it if you good people could interpret my findings and/or guide me on what I should have done. FYI, I have two new mid-bass drivers coming in this week to replace the damaged ones. Here are the two graphs. If there is anything I have missed out, please let me know.
Speakers: Focal Chorus 816v
Specs:
Mic was set up, pointed straight at the centre of the speaker's tweeter. The distance between the tweeter and the tip of the mic was 1m. I did a grille ON and grille OFF measurement but since I listen with the grilles OFF, I have included only those measurements. I can take further measurements if needed.
Specs:
- 2 1/2 way: 16.5cm woofer; 16.5cm mid-bass; 25mm inverted dome tweeter
- 91.5dB Sensitivity
- 8 ohm impedance
- 47Hz - 28KHz frequency response
