- Thread Starter
- #21
Thank you for all your advice, I actually went with the Topping L30 ii from Aliexpress as I was able to negotiate with a seller for $130 for it. might as well keep my DAC and Amp the same to match.There is no better heat dispersion (it does not get warm) nor shielding in this case.
Atom+ is very lightweight by itself and will move on your desk when you tug lightly on the headphone cable. The Hevi one just has more weight to it so it stays put on the desk a little better.
Focusing on the fact I am upgrading my home theater set up more now over the headphones as the HD6XX seems fine for now and I am hoping the Topping L30 ii brings out the value in them. They do already sound a bit better than the PC38X from just being plugged into my case for now.
