Qudelix 5K connection with iPhone 13
Noto
Hi, I’m planning to buy the Qudelix 5K ($110) to use with an iPhone 13 mini.
the idea is to listen lossless audio from Apple Music with a wired hearing device.
I see the cables boxed with the 5K are not compatible with my phone.
Will any of these ones will work?
https://a.co/d/hI5S9db ($15)
https://a.co/d/eS5lvsH ($34)
Or should I consider to buy another DAC with the money I’m planning to spending in the Qudelix+cable (about $150)?
thanks!
Hi @Noto! Welcome to ASR.
The Anker cable I don't think will work.
Here's one that works with the iPhone 13 and is less expensive than the FiiO:
Thanks!
There was not stock for that one on Amazon.
But I found this one I think will work.
Best!
