Hanierlenn
- Joined
- Mar 3, 2025
- Messages
- 1
- Likes
- 0
Hi, I need some advice on this. I just bought the Aune AR5000 and they'll be arriving in two weeks. I've been using the Qudelix 5k for two years, but I don't know if I should buy an amplifier for the AR5000. I know they are easy to drive, but last week I managed to go to a store and try some amplifiers I actually could feel a difference. I'm still new to this and I can't describe exactly what I felt, but everything was better. It wasn't just the volume because I lowered it a lot and I still could feel the difference. I got the idea to use the Qudelix 5k as a dac/preamp using a 3.5mm to RCA cable. I know it's possible because it's in the manual and I was thinking about getting either the Schiit Magni or the Topping L30 or L50, something around $150 or less. If someone has the Aune AR5000 and uses amps with similar power, help me, please. I also have the Letshuoer s12 and Hifiman He400se and I would like to know if these amps work for them too, but my main focus is on the AR5000. Thanks.
