- Joined
- Jul 29, 2019
- Messages
- 352
- Likes
- 1,156
@boXem | audio
1. For who has no idea to read graph, that is 100% right. I thought "In my point of view, I gave as easy explanations as possible with my posting.", but now it seems I lacked thoughtful care about the fact that there are many more people don't have enough background knowledge and reading skills.
I didn't thought people care location of cursor that much.
I don't think you like me very much, but nonetheless, this kind of truthful advice is very helpful. It takes a lot of courage to give the right advice to someone you don't like very much.
Thank you! I should write about limitations more detailed and easy way.
2. That would be ideal. but to do that, I need 555 and some Ref. dummy or amp has co-measured with my protocol and amirm's
Can not be same. But I'll try as possible as I can!
It was sent by company, so I'm afraid it considered as Advertisement.
And who want to know can find it on Google!
Review of my own possessions, I'll mark price!
thanks for your comments! I'll try my best!
@DualTriode Thanks for kind comment and shearing your ideas! I'm really new to this area. members with experiences like you help me a lot!
@Bombadil lol
Nice point!
But to me, buy 7040 means increased power around 2 Ohm load with up to 40 A of current pumping. otherwise 1et400 will do it more clean.
But it is also depends on individuals! as you said.
@amirm I Think some part of 1 and 2 could be debatable, but also It is also a founded claim.
But for 3! I MUST DO THAT! Amp not only amplify 1 kHz so need to test others! Thank you!
Yeeees! I made smokes with some other amps.
As you pointed go higher resolution means more risk I take(other reviewers too.
@restorer-john
Purifi has strong protection. So I think we can short them and see what happens! As my rough(unintended) test, It mutes immediately and return to job as soon as situation cleared.
When I tested Topping amp, It seemed it need manual restart to restore.
@don'ttrustauthority
Can you suggest better words to explain 1% point for me?
If so, can you provide an actual industry standard?
@Holmz
I think it could be help, but it would be quite hard to do that with all amps.
After page 12, I'll read and comment later.
