Interesting, I did not know of Cymax before. Looks ok overall, but I wish they would show internal pictures too.
As a confidence builder why not email Purifi or one of the better amplifier builders like Buckeye Amps (USA), BoXem or Apollon (EU) or MarchAudio (Australia) ? I am sure that they would be happy to advise before you spend your money.Thanks, I didn’t know EPDR didn’t apply to Class D. I like that the 9040 seems to handle wide variations of impedance with ease since the frequency response is flat regardless of impedance. Do other Class D like NcoreX, GAN, etc behave like this?
I almost agree with the first sentence, but I would argue that musicality, as used in the audiophile community, is not related to music, though music is the class of signal typically used to "reveal" a piece of gear's "goodness" or "musicality."Musicality doesn't exist with audio gears. It's music related and has no clear definition whatsoever.
There's already a name for this : it's called transparency and is measurable by several factors.Musicality: the degree to which noise, distortion, frequency anomalies, etc. of a device under test impairs or alters the experience of music or other complex signals
Then, it doesn't exist. Also, since it has as many interpretations as there are audiophiles out there : better call it smurf, it wouldn't change a thing.a purely subjective evaluation, lacking (at present) any agreed upon unit of measurement.
I'm not aware of any formal definition of transparency (in audio) either, nor am I familiar with any single measure of audio transparency. Transparency is simply used analogously with a term from optical science. In that way, it is not unlike the audiophile borrowing of musicality. Also, Dwight David Eisenhower's performance would be difficult, if not impossible, to measure comprehensively or exhaustively. Does this mean he didn't exist or had no significance? The lack of an acceptable or standardized metric does not exclude (or preclude) existence.There's already a name for this : it's called transparency and is measurable by several factors.
Or at least as close as you're reasonably going to get.There is no sound signature. Purifi Amps are wires with gain.
Yes, this is why your system feels kind of empty and what it is you're trying to cure with this amp. Your speakers have a broad suckout between 2-600hz, a peak around 1k, another dip between 2-3k, and a sizeable rise from 6-12k. Basically your speakers are the cause of your issue and no amp will fix it.Thanks for your inputs. I measured my Amati speakers with REW in my room (untreated). It’s 83cm from the front wall with 7.5 deg toe-in so there is room boundary interference. These are using Parasound A31 power amplifier. I ordered a Purifi 9040 amp from Cymax and will test it out in a few weeks. [snip]
I get it: just like clear IS a color! (example: the clearcoat on the color coat of paint on a car).I usually think the opposite: a "no sound signature" IS a sound signature for people used to colored amps.![]()
I was thinking more like black: technically it is absence of light, but we call it a color.I get it: just like clear IS a color! (example: the clearcoat on the color coat of paint on a car).
Clear is a color in spite of it being absent of color.
audiosciencereview.com
Thank you, I perused the thread and, while it is informative, it doesn't quite speak to my mild objection, that terms like transparency and musicality can have meanings independent of any one particular jargon and may have different (useful) meanings in multiple jargons.This thread might help make it a little less random.
Audibility thresholds of amp and DAC measurements
Introduction A recurring theme on ASR is whether or not the various measured qualities of the devices are audible. In this post, I'll present some clear and visual thresholds for when those imperfections can be considered a potentially audible concern. I will not explain the basics of amp/DAC...audiosciencereview.com
Kind of like the speed of darkness is the same as the speed of light.I was thinking more like black: technically it is absence of light, but we call it a color.
Anyway that is the difference between a loudspeaker designed by people who can make beautiful wooden loudspeakers but lack engineering prowess when it comes to actual audio reproduction, and a loudspeaker designed by engineers who try to push the envelope of what is possible with modern knowledge and state of the art materials (no surprise KEF's VP of technology is also a member here).
What dome tweeter doesn't have a breakup mode?Not a good example if you ask me. And what's with the 40kHz ultrasound? KEF forgot to LPF the tweeter?
ASR-specific? Good one.It's just a relatively meaningless, non-specific ASR/audiophile buzzword that gets thrown around here regularly.
Transparency – Ethan Winer, an acoustics expert, discusses how audio electronics can be defined as audibly transparent by four broad categories of measurements and he provides criteria for complete transparency. He states that gear passing all these criteria will not contribute any audible sound of its own and in fact sound the same as any other gear passing the same criteria:
- Frequency Response: 20 hz to 20 Khz +/- 0.1 dB
- Distortion: At least 100 dB (0.001%) below the music while others consider 80 dB (0.01%) to be sufficient and Ethan’s own tests confirm that (see below).
- Noise: At least 100 dB below the music
- Time Based Errors – In the digital world this is jitter and the 100 dB rule applies for jitter components. (photo: Ethan Winer)
Thanks for your inputs. The Dutch 8C also has dips in the range (green line), which to me is honestly expected because even with room correction, the room response exerts a large macro influence over the response. EQ correction should not be overdone anyway because it will over drive the speaker. When I use Dirac room correction, the Sonus Faber does have a smoother curve but the dips still occur at the room modes.Or at least as close as you're reasonably going to get.
Compared to a Dutch and Dutch 8C which is arguably one of the better speakers on the market in terms of meeting what we consider to be "good sound" in an average room, you'll notice that it's generally closer to a gently downward sloping straight line (the teal line is the measured in-room response, the black is an estimation computed from a Klippel Nearfield Scanner's data) Is it perfect? No, of course not, no speaker is - but it's closer.
Pic credit to Erin's Audio Corner.
The Parasound A31 is a 3 channel power amplifier. The center channel is faulty. My current setup is LUMIN P1 network streamer pre-amp to the Parasound A31 to the Sonus Faber Amati G5. XLR Interconnect is Siltech 680i and speaker cable is Wireworld Eclipse 8. Location is not so important since international delivery is easy.For the OP:
1) Where are you located? This makes a difference in equipment availability in different markets.
2) What is wrong with the Parasound amp? You said it is faulty.
3) Besides the Sonus Faber speakers and Parasound amp, what is the rest of your equipment?
Thanks, I agree about not degrading with a tube so I’ve dropped the idea.As a confidence builder why not email Purifi or one of the better amplifier builders like Buckeye Amps (USA), BoXem or Apollon (EU) or MarchAudio (Australia) ? I am sure that they would be happy to advise before you spend your money.
I wouldn’t waste my money however by degrading a state of the art amplifier with a tube/valve first stage which will only add noise and distortion. The use of Weiss opamps is unlikely to give a discernible difference over the standard, very high quality, opamps from Texas Instruments as recommended by Bruno Putzeys.
Use a parametric equalizer (PEQ) working in the digital domain (eg RME DAC) if you wish to fine tune the sound from a particular recording.
