Denosaur22
Asking Price: $2,200.00
MSRP: $2,569.00
Shipping: Included, US Only
VTV AMPLIFIER
Original purchase is from VTV Amplifier on August 22, 2021 as a dual monoblock with the 1ET-400A modules. I sent this unit back to VTV Amplifier on May 7, 2022 to upgrade to the 1ET-7040SA modules.
With instruction from VTV Amplifier, I did install a standard PC jumper onto JP1 that is located on the input buffer board to increase the gain to 14db as our speakers are extremely sensitive and require the gain. If you do not need this additional gain, you can remove the jumpers.
At your request, I can provide the original proof of purchase and receipts to include the upgrade.
https://vtvamplifier.com/product/vt...power-dual-mono-two-power-supplies-amplifier/
MSRP: $2,569.00
VTV AMPLIFIER
- HIGH POWER MODULE: Purifi 1ET-7040SA
- Dual Mono
- TWO POWER SUPPLIES: Hypex SMPS1200A400
- CUSTOM INPUT BUFFER: PR Weiss OP2-BA Opamp
- BINDING POSTS: SPEAKON
- CASE: Custom Design, Aluminum with Blue LED Pilot (LED may be dimmed or shut-off by switch)
- Fully Balanced Design
- EMI/RFI Filtered AC Inlet
- MOGAMI Input Wiring Standard
- Silver-Coated Speaker Output Wiring with TFE Jacket
- DIMENSIONS – Width: 19″ x Depth: 20″ x Height: 3.75” (dimensions do not including speaker posts), Weight: 32 lbs
- 950 watts @ 2 ohm
- 500 watts @ 4 ohm
- 250 watts @ 8 ohm
- Signal-to-Noise Ratio: 129dB
- Frequency Response: 0 - 60KHz
- THD: 0.0008% (200W, 4Ω, 20Hz-20kHz)
