problem with topping dx3 and dt 990 pro
roberto96
Hello everyone!
After many sacrifices and weeks, read the information on this forum. managed to retrieve a Topping dx3 pro and the DT990 Pro.
The purchase was made to be able to hear uncompromising music and play while hearing an audio as realistic as possible.
I connected the headphones to the topping and the latter to the pc via usb, I have the latest topping drivers installed.
After this short intro, I'm trying the setup with the windows volume at 100% and the topping volume at -0.0db, I can hear an adequately high volume with the gain at +9.0, without the gain it seems to me that the audio is bass.
Am I doing something wrong? Seeing around I see people with -20db not complaining.
Many thanks in advance!
R
roberto96
I also add that these are my first experiences with dac / amp and studio headphones, I come from hyperx cloud 2.
Paradoxically I felt louder with the headphones I had before.
bravomail
Hello everyone!
try different source material - different songs, maybe they are recorded quiet.
also set volume normalization per track in your player.
R
roberto96
Thanks for the reply. Even on youtube, spotify or while playing the volume is low. For example when I had the hyperx cloud 2 in game I had the volume at 30% now with the new setup I have the volume at 60% and the volume is still low.
threni
/dev/null
Windows has multiple volume levels; a master one and per-device ones. Are they all on full volume? Do you have any other headphones you can try it with?
R
roberto96
Thanks for the reply. Yes, I checked the windows mix volume and it's all on max. I'll tell you more, I tried to connect the headphones directly to the PC and the volume difference is small
threni
/dev/null
Maybe take a piece of music (eg .flac or .mp3 file) and use Audacity to check it's loud (or normalize it) in case you're playing "quiet" files. The headphones are 250ohms; not sure how sensitive they are but that's getting on for fairly high.
R
roberto96
I also think they should sound high. How could I solve? is it a problem of the topping dx3?
ron46
Did you solved it? I want to buy a dac/amp for 990 pro around 200euros but don't know what to buy
ron46
In the end I made the return of the topping dx3 because in my opinion it didn't sound like it should. I bought the fiio k5pro and I am fine
Oh k, maybe i'll try it, since theres nothing to try apart the topping nx4, it costs 210 from amazon.it, do you know maybe other dac/amps or combos that i could try with the 990s?
R
roberto96
Let's say that the candidates for the combo are the topping dx3 or the fiio k5pro, for separate dac / amp I abstain from the discussion because unfortunately I am not informed
