ethanhallbeyer
- Joined
- Feb 24, 2019
- Messages
- 175
- Likes
- 50
I am putting together the following system and don’t really know anything about impedance matching, so would appreciate some input on what I may need to watch out for, if anything:
- SOURCE: PC or iPAD via USB to DAC
- DAC: Denafrips Ares II w/ balanced XLR out
- AMP: Purifi or NC1200 monoblocks (balanced XLR in)
-HPA: Monoprice 789
-Headphones: Drop HD-6xx w/ XLR cable
- SPEAKERS: KEF LS50 & Magnepans (likely LRS for starters)
I’ve had my general configuration like above, except with different components, in the past. The main reason was I tended to fall into the camp of those who believe you get better sound quality by not using a pre-amp at all. Another plus was the cost savings from not having a pre-amp. Now, I’m considering a tube pre-amp, possibly, like the Schiit Freya+, which is balanced and has received great reviews. I’d do this if I want to get a different sound out of my setup.
In addition to the components above, I have a JBL M-Patch-2 XLR switch with volume knob (like a passive pre-amp). I also have an NobSound speaker switcher with remote. These two units let me use the same DAC with balanced XLR out to the JBL XLR switch, which has XLR outs to my headphone amp and also to my speaker amp. From there, the speaker cables connect to the NobSound speaker switcher, and two sets of binding posts allow me to output to 2 different pairs of speakers. One pair is used with the KEF LS50 for near-field applications and analytical listening while using my PC, the other is to be for just sitting back enjoying the music on a different set of speakers in a different part of the room.
This has worked pretty well for me so far, but I wonder if I may not be getting the best sound possible that way.
Is there any way that I can determine if I’m getting optimal results this way or not? would impedance matching be the answer? would I be better off with two separate DACs and amps?
Thanks in advance!
-HPA: Monoprice 789
Thanks in advance!
