HI everyone, this is my first post here. I had been following this forum for long, but I think its time that I pitch in for asking something which had been bothering me for some time. Attached is an example of a speaker with a decent frequency response, and distortion figures. But when I look at the directivity from this graph, it is all around the place. Such a speaker, will it sound good anywhere?
To me everything here looks good , until 60 degree and 90 degree respsonse. Those have a huge hump in upper mids, unlike the state of the art speakers. Or am I reading this graph wrong?
One might assume that off-axis directivity starts to depart from acceptable at about 45°. That would leave about one third (measured by surface area) of the of full frontal half-sphere left intact, but the other two third of the frontal half-sphere would be affected. Let alone the backward half-sphere.
One could say, that the good frontal portion is only 30% of the whole story. And only so if one is graceful enough to ignore the backward sphere altogether.
The degree of contamination of the reverberant sound field depends on the reflection coefficient of the rooms's boundaries in the referring frequency range. In this particular case you would need to dampen at 4kHz a lot, while not also dampen the range below and above, which is actually hard o do.
That is, why the spinorama was invented. To avoid specifically that glaring sound from common BBC-like 2-way designs in peoples homes. The BBC coped with it by inventing the British 'vocing' with deliberately subdued treble, and not to forget the infamous BBC dip.
Btw: I can read German--the text says: "perfectly balanced". Not really, but just typically bad, as expected.
