This is a teardown of the recently reviewed Peavey USB-P transformer coupled DAC. The internals are simple enough:
Data and power are provided via the USB bus. The core of the system is a on-chip USB DAC, the TI/BurBrown PCM2705. This is a low performance DAC designed for quick implementations. Here are the TI measurements for it:
I have converted the THD+N percentages to SINAD (in red). As you see, there are two implementations: one with USB power with worse results (left) and the other with stand-alone power supply (right). Neither is much to write home about. Ours is the one on the left which best case has a SINAD of 78 dB. In the review I got around 74 dB. The reduction is due to use of transformers on the output to provide isolated/balanced output (the main reason for this device's existence).
Transformers can generate a lot of distortions especially in lower frequencies. Let's go ahead and measure that using USB-P:
At 20 Hz and full digital level input, distortion shoots up to nearly 2% for a SINAD of around 35 dB! Most of our measurements are at 1 kHz which gives these a ton of benefit of doubt.
Lowering the output signal level improves transformer distortion but then signal to noise ratio worsens so there is not a lot of gain to be had as you see in the green and blue lines above.
I suspect this level of distortion is very much audible. So only use this device if you have to and performance is not critical.
Any donations are appreciated using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
