For the DAC that he measured - yes.but Archimago's DSD256 plots in all tests (THD/IMD/DNR) are pretty pathetic.
Cannot generalise....
I think Archimago must obtain some decent DSD256 test signal or something else is at play.Your DSD128 plot with -60dB ESS volume control looks close enough to Archimago's DSD128 DNR plot which did not use the ESS volume control, but Archimago's DSD256 plots in all tests (THD/IMD/DNR) are pretty pathetic.
Anyway, according to your tests, using the ESS volume control makes DSD measure like PCM.
Similar results applies to Oppo UDP205 and Topping D90SE too that Archimago tested too, and...For the DAC that he measured - yes.
Regardless of how the volume control actually works, the results show that using the ESS volume control on DSD input caused distortion when compared to a test signal generated at for example -20 or -30dB.With ESS, with DSD input you get 1-bit DSD converted to 32-bits for digital volume control.
But the original sample rate is maintained, so you bypass all ESS oversampling DSP.
So it stays at the DSD MHz original sample rate.
The DSD256 distortion does not happen on other DACs Archimago tested, for example, RME ADI-2 series. So it is not related to the input DSD256 signal at all.I think Archimago must obtain some decent DSD256 test signal or something else is at play.
At my rig DSD256 is not much different than DSD128:
Almost the same (about 2db worst) DR but decent overall.
It seems all ESS Dac's with "preamp mode" didn't bypass the PCM conversion. May be in direct as well?Similar results applies to Oppo UDP205 and Topping D90SE too that Archimago tested too, and...
Even if there is conversion, if the conversion quality is decent there should be no obvious distortion, so I am a bit disappointed.It seems all ESS Dac's with "preamp mode" didn't bypass the PCM conversion. May be in direct as well?
You're right,all test here (big disclaimer for that "here" ) show that the main reason is VC overall.Even if there is conversion, if the conversion quality is decent there should be no obvious distortion, so I am a bit disappointed.
The conversation itself is not the problem, later how it's handled in the following stages seem to be the problem (Hump I/V conversation HF glitches....)Even if there is conversion, if the conversion quality is decent there should be no obvious distortion, so I am a bit disappointed.
With a few of the DACs that I used for testing (SMSL DO100, RME ADI-2 Pro FS) I found no measurable difference between DoP and Native DSD. Multitone makes it easy to switch between these by just changing one setting. It was also quite nice to be able to output 512x48k DSD test signal and capture it using 768k ADCNot much of a difference than DoP I think but still nice and clean without the added "energy" but at the expense of couple of dbs' elevated noise compared with PCM.
Such DSD tests (but not only tests,even single test signals) were simply non-existent before you implement (or better say invent them from ground up) them in Multitone Analyzer.With a few of the DACs that I used for testing (SMSL DO100, RME ADI-2 Pro FS) I found no measurable difference between DoP and Native DSD. Multitone makes it easy to switch between these by just changing one setting. It was also quite nice to be able to output 512x48k DSD test signal and capture it using 768k ADC
What DAC is this because the DSD noise should not be rising at 40kHz for DSD512It was also quite nice to be able to output 512x48k DSD test signal and capture it using 768k ADC![]()
Should be more like 200kHZ
This doesnt look like DSD512 is being converted to analgueBy the way, I know you use HQPlayer, so here's a comparison with the same DAC. HQPlayer vs. Multitone. Same signal upsampled to 512x44.1k by both, HQP is red, MTA is blue. The noise floor appears pretty identical despite completely different implementation. H3 and higher order harmonics seem a bit higher with HQP, not sure why:
The conversion might be running at a lower rate
For example there are AK4499EX DACs out there supporting DSD512 input
But it is well known this chip actually runs at DSD128 and DSD256
What DSD rate is this?THD vs level DSD
