It should work
I asked MiniDSP about this last year, they said:Is it possible to use the HTx with Linux?
In the software section I only see Windows and Mac.
Was this level matched? I'd be surprised at s marked audible difference between the two.I compared it to a Topping DX7 Pro+ via balanced connections, connected to a Purifi amp. I switched off all the DSP. The difference was marked. The Topping was a lot better.
Whether it's pointless level matching depends on what it is you're trying to achieve. If you want to know whether you can really hear a difference then level matching, blinding etc. is absolutely necessary.No. If the difference is small isn't it pointless level matching because it would take someone maybe one minute to switch DACs? The difference was large enough for me to completely confident.
Id not go down this road any further . You will convince nobody here that your claim has any validity unless you apply basic controls. Which means precise level matching and not knowing which unit is playing .It's clear what I'm trying to acheive. Surely you're not saying that I can't really hear a difference are you because that's like asking someone to tell the difference between cheddar and cottage cheese, the difference is obvious., and then saying they need to be blind to be able to tell!?
www.audiosciencereview.com
I have not tried that on the HTx, but I could. Don't see any point though because if XLR outs are use, the signal flow to the power amp will be balanced. As far as the "true balance...", I think people over complicate things often not defining what they meant by "true balance".Has anyone tried RCA-ins to XLR-outs on the HTx? - are the end results a true balanced workflow?
I'm not sure I have ever heard of any piece of equipment that did not output a balanced signal when outputting over the balanced outputs, regardless of how the audio got in in the first place.Are you able to confirm that for me? I'll appreciate it.
Not sure if the signal is corrected or will the sound be attenuates similar to using an RCA to XLR cable which removes the balanced aspect.
I assume that using the balanced output on the HTx will ensure a truly balanced connection.
It gets difficult to discuss because people have different ideas about what 'balanced' means, and there are several ways to achieve it that have different properties. Some don't regard an output that has the same impedance on both hot and cold, but only drives one, as being 'proper' despite that doing what's needed for the CMRR benefit of balanced operation. 'The G Word' covers this, and the example preamp uses such an output.I'm not sure I have ever heard of any piece of equipment that did not output a balanced signal when outputting over the balanced outputs, regardless of how the audio got in in the first place.
I replicate this graph with the most recent beta firmware that introduces the input EQ feature. Still not the most amusing multitone, but now, the bottom is at around -110dB comparing to the old graph. So, there is improvement.I get this messy result
