Paid vs Free Room EQ for Stereo
Chr1
I am wondering what advantages paid DSP software such as DIRAC has over the cheaper/free options for stereo playback?
I use MathAudio's RoomEQ, which is free for use with Foobar2000. It has made a massive improvement in sound quality for me as I previously didn't use any DSP/room correction. I use it for a combined system involving either 2x Neumann KH310s or Tannoy V12s with a pair of BK XXLS400FF stereo subs. Here's the thing though : it is free and very easy to set up... So this makes me think there has to be a catch/tradeoff.
ie what do DIRAC, Rephase etc do that MathAudio doesn't?
Anyway, any info most welcome, and apologies if this has been covered elsewhere. Couldn't find much via search...
Thanks in advance.
staticV3
From my POV, paid solutions tend to have more complex backends and/or more user friendly frontends.
voodooless
Netherlands
Here's the thing though : it is free and very easy to set up... So this makes me think there has to be a catch/tradeoff. ie what do DIRAC, Rephase etc do that MathAudio doesn't?
System wide EQ? Math audio can do that as well, and then it’s no longer free… the only thing free is the Foobar plugin.
As with all things audio, price is rarely an indicator of performance.
Chr1
Chr1
Thanks. I guess the thing that I find so weird is that MathAudio is almost too easy. Takes a matter of minutes to plug in a UMIK-1, fire off some test tones and choose a level/curve for whatever speakers you are using. Too easy surely?
voodooless
Netherlands
Dirac isn’t more complex… start, measure a few points, draw your curve, save filter preset.
Chr1
Chr1
OK, thanks. But what advantages does it have over MathAudio RoomEQ? From what I can make out it is fairly pricey. RoomEQ is free. I am assuming that there's a catch... Or no?
Perhaps RoomEQ, like Foobar2000 is just very good free software...either way, I am a happy camper.
voodooless
Netherlands
Again, it’s not free. It’s only free as a Foobar plugin. If you use Foobar, lucky you, if not, you pay.
Chr1
Chr1
Cool, thanks. Seems like a no-brainier if it's just for stereo playback and you'd rather avoid pricey alternatives. Foobar and MathAudio it is then.
Cheers.
Snarfie
Netherlands
Thats correct the systemwide solution is not free but for what it's worth if i Listen to music it's 99% using Foobar 2000. Further more Foobar is for free and extremely complete. If i'm correct it is a populair audiophile mediaplayer in a survey here on ASR an by far most used.
https://www.audiosciencereview.com/forum/index.php?threads/audiophile-music-player-for-windows-mac-and-your-opinion.42014/page-4
Archimago made also a informative comparison.
The simplicity regarding Mathaudio is astounding for tech dummies like me
:facepalm:
Besides the Foobar version (used with WASAPI driver) i also use the systemwide version to compensate for gain differences (i noticed that it could damage my speakers if not used ) However the systemwide version or any other mediaplayer is barely used.
