PAC LC-1 Passive Volume Control Review
Rate this product:
    Votes: 2 1.7%
    Votes: 24 20.9%
  • 3. Fine (happy panther
    Votes: 76 66.1%
    Votes: 13 11.3%
I use one of these to control subwoofer level -- without getting on my knees, reaching around to adjust the pot on the back of the sub, and getting back to my listening spot to check if I got it right. Seeing as that's essentially a very low frequency mono application, this gadget is just dandy for the job -- small, absurdly cheap, and very handy.
THIS
Thanks for the test data
Sadly this is one of those products where a sample size of one is of limited value, Simply due to the variability of the potentiometer.
This is the review and detailed measurements of the PAC LC-1 passive attenuator. It was kindly purchased new by a member and costs just $9.50 including shipping from Amazon.
I must say for such a cheap device, the RCA cables feely nice and supple. And volume control itself is smooth. Inside there is a tiny PCB where all the cross connections are made. From documentation it seems that it is for car stereos but obviously you can also use it for home audio as long as all you want is attenuation.
PAC LC-1 Measurements
I used the LC-1 between my Audio Precision APx555 unbalanced input and output across two 6 foot sections of cabling. Here is the dashboard:
So at this volume level, performance is completely transparent. Let's see how good channel separation is:
So there is a distinct hit but it is still more than good enough for most things.
The issue with passive volume controls is that it messes with the impedance of the device you are connecting to. This in turn causes a frequency response error as you can see below:
The level of attenuation may be worse in your device. As is, it is not too bad at roughly 1 dB at 20 kHz.
What I didn't like is the taper that they selected. Most of the range is useless as you only get meaningful attenuation once you are below 12:00 o'clock. That accentuates the channel differential in the pot used:
Of course your example may be worse or better than this. Company rates the unit at ± 8 dB. Not sure how you get +8 dB from a passive control. Assuming they only mean -8 dB, then they are meeting spec.
A passive volume control is going to be bring its native problems so there is no getting around that. In that context, for less than $10, you are getting what looks like a high quality little box and cabling. Yes, the box is plastic but still, I like the total package and am going to recommend the PAC LC-1.
@amirm
For such a device, or even for an active preamp, I think an important question is:
How does it perform compared to digital attenuation ?
So, maybe, a set of a few SINAD measurements, starting from a normalised input (2V unbalanced here) with an attenuation of min, 6dB, 24dB, 42dB, 60dB, compared to a typical DAC SINAD (SNR) slope ?
I know. It's more work.
It is also that the wear and tear(i hope it is correct translate for german "Verschleiss" of such stereo pots is very high. I have a new passive controller test and when it was new i measured it several times channel inbalance was less than 0,3 db thats good. after 1 month of use, i get then channel inbalance less than 0,7 db
how much per day do the device developer count a user change the volume ?
I look youtube music videos and shorts much, and i change volume at least 30 times per day or maybe more. in 30 days then it is 900 times
so i notice now that such analog stereo pots(also in most USB studio audio boxes should not use often), and the bad thing is, the channel inbalance over time get most in the area you use most. It is always reproducable and my passive controller do not pot crackle until now. Seem happen because the pressure betweeen left and right pot is diffrent, so wear and tear is diffrent for left and right channel. I have no dusty room, and i do not smoke, and i touch and move the pot very carefully
maybe testers should do a pot durability test, measure again after 1000 moves diffrence between left and right. thats a thing pot developers should do, or tell how much times they allow to move the pot. the frequency response is always great, When left and right is more than 0.5 db diffrent it sound strange, miss clarity and location and room feeling and cause ear fatigue, maybe because depend on setting the diffrences change. it is a shame, near all devices do FR of 0,3 db correct, but pots do bad left right inbalance. My older volukme controller, have 2 db diffrence, before i replace them but i did not know that it is channel inbalance, because i did not thought that pots have such a large wear and tear. and 0.5 db on low volume is more influnece as 0.5 db at higher volume
It is easy to convert this RCA stereo volume control into a balanced XLR mono volume control.
The L/R earths go to pin 1 on the XLR . Pin 2 is positive (R) and pin 3 is negative (L)
Useful if you need to add a volume control to an external subwoofer amplifier.
