PA5 & E50 & rapsberry - how to get it work :-)
Foxenfurter
London
Have they given you a barrel to usb connector? I suggest buying a a cheap (<20 GBP) multi port usb PSU, Anker seems to be a decent brand or anything you already have that works. It just needs to be electrically safe and not buzz.
MCH
bh69
bh69
Pilsen, Czech Republic
Probably hard question but can somebody compare sound of Topping E50 vs Audiolab M-DAC (old first version) ?
I know that M-DAC has only 24/96 and no MQA, but it doesnt's bother me. I only need to know if there would be some difference in sound.
I have M-DAC and I'm considering whether to buy only the PA5 or also the E50. If there would be no the difference in sound, it's probably useless and I can stay with the M-DAC.
JamesYeomans
JamesYeomans
Unless you’re having ground loop issues & need the balanced connection of the E50
kchap
Melbourne, Oz
I use the E50 with with standard (out of the box) USB A to barrel connector cable plugged into an AC power board equipped with a pair of 5 V USB power outlets. The RPi 4B uses the standard recommended 5 V USB plug pack. I do not have any issues with noise. The suggestion of using a heat sink or a metal case for RPi is a good one, I use an Argon40 case
Regarding your Ethernet cable, 35 m is no problem at all but when you said 2 m underground that suggests outdoor cabling. Most Ethernet equipment is not rated for outdoor use. If use you live in an are prone to lightning I would use fibre. Do not spend your money on expensive linear PSUs buy a pair of cheap Ethernet media converters and fibre.
bh69
bh69
It leads from the neighboring house to mine, 20m away, all the way in a plastic pipe at least 0.5m underground
Triliza
Europe
There is no adapter with E50 provided, some 5V USB should be used
Haven't tried it but I suppose Pi 4 would be able to supply power to E50 |(usb 3) and an external hard drive, assuming you are gone to use the official power adapter or an equivalent one. How did Amir connected it during testing, I suppose to his laptop. Or just use any spare 5V/2A usb charger with the provided barrel adapter.
it's pretty long in my case (at least 35m, 20m under ground)
If you have already an ethernet cable at your place and it's working, just use a ethernet splitter to connect Pi also. If it works now with youtube for example, it will be fine for streaming music. Then you can create a wi-fi hotspot on the Pi and connect with your phone or tablet to it, same way you'd connect to a router.
kchap
Melbourne, Oz
I meant to say 20 m not 2 m. Standard consumer enterprise grade electrical Ethernet ports are not rated for outdoor use and may be considered a safety hazard. I would not recommend running Ethernet Cat 5/6 cable underground.
bh69
bh69
what hazard ? do you mean if lightningh would hit the house directly it would induce big current into ethernet despite it's under ground ? I think this risiko is similar as cable indoor near lightning conductor outside on wall, isn't it ?
bh69
bh69
What about USB isolator Topping HS-01 ? It seems to be best solution to eliminating all noise from Pi. In case it really works :)
MCH
I don't think you need it
Reactions: EdW
MCH
I don't know, i have used different pi, from the zero to the 4, with different dacs, from very cheap dongles to topping D30pro and different power supplies, from official raspberry pi to throwaway phone charger and never ever detected any noise.
Maybe you do, my recommendation before buying a 60 euros filter is wait and see :)
pma
Prague
I don't know, I asked. Power supply is not there (eshop info), only instruction tu use some 5V USB one.
Topping says this:
and there is no specification of current consumption at their web page. In case of Topping, many parameters are missing and some look suspicious. Try to ask @JohnYang1997 here or ask Topping technical support.
kchap
Melbourne, Oz
I'm in telecommunications. At some small sites the equipment may be in multiple huts, sometimes shipping containers. Except in situations where we are using special "ruggedized" equipment we cannot run CAT5/6 cabled between the huts. It's your decision, but I would not do it.
As an observation, most lightning damage is caused by induction. Direct hits on cable usually vaporize the cable.
I would not worry about noise. When it was a genuine concern it was more likely a problem DAC HATs not external USB DACs. In the unlikely event that you do have a noise problem then investigate.
Topping says this:
According to the manual the E50 uses less than 2.5W. A standard 5V 2A supply will have plenty of power.
JayJay
I'm using a similar setup. Raspi 4 running Moode --> Topping D10 Balanced --> PA5 (via balanced TRS cables). My 2 Cents:
- No need for extra power for the DAC, the PI runs it from it's integrated 5V via USB. One should not worry about noise etc.
- "Clean" Raspberry power supply is more important for the Raspberry itself. The Raspberry boards (starting with 3B) are sensitive to low voltage. You'd see a "low voltage" message in the kernel ring buffer in Linux ("dmesg" as root user) or it would not be stable at all. So don't worry about some magic power supplies that do better than others. If the Raspberry does not complain, you're good!
- Stay away from "audiophile" hardware like power supplies, cables etc. What you need is a 5V/2A Raspberry-rated power supply (they're cheap on Amazon and someone in this thread pointed out that there are nice bundles for a few bucks), a "normal" TRS (=balanced) cable from your trusted supplier (no extra super expensive gold-plated whatsoever magic cables).
- I've even run it on Raspberry PI 3 and 2 without any issues. I mention this because Raspberry 4 are hard to get these days and there are messages about jitter etc from older Raspberry boards due to USB and ethernet sharing the same bus. Not saying this can't happen but I've not experienced any issues ever.
Here's my setup:
P.S. the first pic has no Raspberry board inside the case and is not wired as you can see :). The second one is fully loaded and it sounds great!
bh69
bh69
Is there some good amplifier on market (or DIY) that
1/ has XLR input for 4V signal level
2/ has lowest gain possible (10-15dB or less, even 0dB would be OK)
