So I swapped from a desktop to a laptop... and many other changes occurred, but the rest of the setup is basically the same - Same monitor, same speakers, I guess the monitor cable changed from DP to HDMI. The entire setup runs off a single wall plug and one power strip that is daisy chained to another power strip due to length issues.
And now my screen blacks out whenever the dryer is switched on.
And I used to have line-filters with one IEC inlet and one wall-socket outlet but those have gone MIA
And with a need to order from element14 or RS soon I thought might as well get something.
Qn1: I see surge protector products, they mean they use MOV, how useful are they against daily hairdryer stuff? I'm under the impression that MOV are "consumables" and they don't work well against small spikes anyway. However a manufacturer brochure said MOV is for other appliances switching on/off, and line filter is for noise.
Qn2: A good line filter is CLC, but to save on labor and also keep things simple and safe, if I DIY I may just go for a single C, heck I may just find some unused ATX PSU and plug it in. How useful is just a single C against a hair dryer in the other room?
