- Thread Starter
- #41
No, but I've heard of it, and I'm familiar with A.N.T. I need to purchase one of his tapes for setting the speed on my Nakamichi cassette deck, but just haven't done it yet. But the test tape one needs for accurate wow and flutter testing probably requires more precision than the tape I'm using for frequency and level setting. I could probably record a 3-KHz signal, but the same wow and flutter that would be present during recording would come back during playback, with unpredictable results.Have you used this software wow and flutter meter?
So, I've done more testing with the pinch roller reversed where it works better. With a 10 KHz signal at a nominal -8 dBm (0VU), and with my ADC set to level that at -6 dB digital level, and when recording the Tape Monitor output (i.e., what's actually coming off the playback head) to Audacity, the loudest noise I'm seeing is a power hum at 60 Hz of -47dB, with its harmonics below that. The second harmonic of the signal is at -72 dB. There are lots of noise products in the -60's and lower. Specified performance is 45 dB S/N, but with the exception of power hum it's better than that. I could notch 60 Hz on playback and remove that one altogether. Hiss is definitely audible, of course, and those noise products do add up to hiss.
When recording the Source Monitor to Audacity (which is just what is coming in from the signal generator through the inputs to the deck, but includes a partial trip through the electronics to get to the outputs of the deck), all the power hum and its harmonics are there, but a few dB lower. But the hiss, of course, is not.
With 1 KHz at 0 VU on the Teac and the Source Monitor recorded at 0 dBFS, power hum is the loudest noise at -52 dB. The power hum's third harmonic is nearly as loud as that. The Tape Monitor output enlarges the power hum to -46 dB, with the signal still at 0 dBFS. Harmonic distortion of the input signal is at -47 dB (second harmonic) with others much lower. Spec'd S/N is -48 dB, which is is pretty close to. The specifications for this deck claim 1.5% THD when recorded at specified input level, which this is. With the Maxell tape, this deck beats that substantially. There is some close-in spectrum right around the signal frequency which is probably product of wow and flutter. Those seem to be no higher than the -30's, but they are so close in that I doubt they are audible. My signal generator is only spec'd to 1% at full voltage output (which this is not by any means). I don't have a distortion analyzer beyond what I read from these spectrograms.
Recorded frequency response is 30 Hz to 17 KHz, +/- 1 dB, recorded at 0 VU (nominally -8 dBm at the inputs). Recorded at -8 VU (-18 dBm at the inputs), the frequency response is 27 Hz to 24 KHz, -1 to +2 dB. This is on Maxell UD tape at 7-1/2 ips in high bias.
I'm calling this one ready for my project, and I'm going to put the covers back on it. But I will still try to find a (really, this time) new Teac roller or will have one rebuilt when Terry Witt is back in service.
Rick "old but no longer as crappy" Denney
