sam_adams
- Joined
- Dec 24, 2019
- Messages
- 1,030
- Likes
- 2,560
You can still download MusicScope and use it without a license.
YOINK!
Yeah, good call, background noise like fans and air conditioners and how the physics of the room itself boosts/lowers certain frequencies, etc.And the acoustic noise floor of the room which is probably worse than 16 bit.
I think this is important. We can argue DSD vs PCM vs high resolution vs redbook until the cows come home, but you have to like what you're listening to. The latest album they have by Scabaret (to me) is amazing from beginning to end, amazing talent by the trio of women. Also for $29 for an SACD + DVD with digital master audio files is a good deal to me.Well, to be fair to PS Audio, Amir did not like the music selection or the price. So that was two negatives right there before looking at the DSD format failure. So the review "seems" more negative than it really should be.
All things considered I am not sure with anything that isn't pure electronic music, that you can get more than about 70-75 db of real range with recordings. That can be somewhat deceptive. Most noise is low in frequency, and our ear breaks up the sound spectrum into 30 or so bands. So some bands of our hearing in the midrange can approach more like 90 db with a recording, but that is probably about it even then. Might be an interesting thread to consider just this topic though we've had a few more or less on this topic before.I meant in general, can the analog recording equipment be quiet enough to take advantage of the DR afforded by 24-bit digital recording. Not only the mixing desk, you also have to keep in mind the SNR of the microphones, microphone amps, the grounding scheme employed with the recording equipment, etc., even before it hits an A/D converter.
what i want to see is this test with that audio device that amir, used dsd to see if paul sends the dsd into clipping , no seriously i want to see if this dsd can show "the rancor scene" from 'return of the jedi' what the pcm looks like on laserdisc . i'm not fully convincedWow... it's like the old joke... "How can you tell when Paul is lying? His lips are moving".
3 dB down, half-power-point, corner-freq, cut-off freq or whatever one calls it it's all more work to do for the amp class(s) with the higher bandwidth.I happen think DSD is an interesting format. Does it have a lot of noise in the high-register, yes, but we can't hear it (and doubtfully our loudspeakers could reproduce it anyway), so it likely doesn't matter.
One could say the same about browsing the modern web with all the extra scripts these days. But some of those sites are useful, if inefficient. Including this site3 dB down, half-power-point, corner-freq, cut-off freq or whatever one calls it it's all more work to do for the amp class(s) with the higher bandwidth.
Agree - and agree that that's a common problem with "audiophile labels".The problem is that they didn't deliver on the other components either. This is a classic problem with audiophile recordings done this way in that they scrap the barrel to try to find someone who is willing to sign up to such projects for so little sales to audio nerds.
that was so elusively in the back of my mind far from thought and yes i agree i don't like the layout of the new google main page it sucks so does one with soviet airplane firefox i think its cruel of that company to set a fox on fire .One could say the same about browsing the modern web with all the extra scripts these days. But some of those sites are useful, if inefficient. Including this site
The tasty angel's share (...and maybe the lion's too.) I suppose although the amplifier power wasted and abused in this sort of power gobbling bandwidth consumption by raw noise data is simply not required and wastes resources. I'm a first person shooter gamer and so I appreciate the high frame rate action, thermal issues and I am familiar with downclocking when quiescent for power savings and longevity. Most of the time it is multiplier reduced down to ~800MHz.One could say the same about browsing the modern web with all the extra scripts these days. But some of those sites are useful, if inefficient. Including this site
closed after 1 1/2 hours, expectedSomeone opened a thread about this test on the the PS Audio forum.
There was not much rejoicing.
Yes, glad I'm not the only to do this. Most of the time there is little there to hear at all. No way can it matter if masked by sub 20khz content.@amirm a good way to illustrate that there's no music in this ultrasonic noise is to pitch shift the. I've done this and it's just noise, maybe with some minor rhythmic pulsations but nothing like upper harmonics of instruments.
I seem to remember I did it in audacity. High pass the file at 22khz with a steep slope if that's an option. Then pitch shift down by 6 octaves or so. 22khz becomes 344 hz.
It becomes quite apparent that this is pure noise.
That’s not how sampling works re your point 2 you resolve all information there is up to halve the sampling rate , so you won’t get more information because you already have all the information to perfectly reconstruct the signal below 20 kHz .Hey Amir, great work as always, couple of questions.
1) I suppose Octave would make the point that not having filters involved would improve the audio quality, any logic to that?
2) We always talk of the extra over 22KHz but isn't the real point of high res to give finer gradations in the audio band?
No, because Octave Records is recording to DSD but mixing on a 30 year old Studer 900 series mixing desk. Nice desk, but no where close to 24-bit SNR.
