NOS DAC in-band distortion
manisandher
Royal Leamington Spa, UK
Here's the output of my DAC running in 24/44.1 NOS mode (1kHz sine wave input):
I understand that the out-of-band (>22.05kHz) distortion is created by imaging above the Nyquist frequency. What I don't understand is what's causing the in-band (<22.05kHz) distortion.
Here's the NOS output up to 22.05kHz:
And here it is with an 8x OS reconstruction filter:
What's causing the distortion in the NOS case?
In a recent BorderPatrol DAC review in Stereophile, JA refers to it as "aliased image energy". This makes no sense to me. My understanding is that "aliasing" occurs during analogue-to-digital conversion, where any signal above the Nyquist frequency is 'folded back' in-band. "Imaging" occurs during digital-to-analogue conversion, where any signal beyond the Nyquist frequency is 'replicated forward' out-of-band.
(I've noticed Amir using "aliasing" when talking about DACs too.)
Is JA correct to use the term "aliased image energy" for NOS DAC in-band distortion? If not, what's causing it?
Mani.
Hayabusa
Abu Dhabi
Mani.
Most of them are harmonic distortion of the 1kHz. The peak seems to be at the 3rd harmonic (3KHz, -90db?) (there is no grid, so I have to guess)
manisandher
manisandher
Typically this is IMD products of images.
JA seems to make a distinction between what he calls "aliased images in the audioband" and IMD tones.
Mani.
manisandher
manisandher
The 1kHz harmonics are clear from the 8x OS plot. It's the extra noise between the harmonics on the NOS plot that I'm trying to understand.
Mani.
pma
Prague
It looks similarly like non-dithered 16-bit, however it is probably not the case.
Hayabusa
Abu Dhabi
Mani.
These are below +/- 125dB, I would not worry about them :)
manisandher
manisandher
Not worried. Just trying to understand in-band NOS behaviour ;).
Mani.
manisandher
manisandher
A DAC without a reconstruction filter is broken by design. Moral of the story is use a reconstruction filter.
I understand why a reconstruction filter is a good idea to stop ultrasonics. But why does it reduce in-band distortion too?
Mani.
Mani.
That is unrelated to this comment. You are getting intermodulation of the aliased components.
Blumlein 88
Mani.
Yes, see Amir's comment. IMD of the aliased ultrasonics down into the audible band. So when you use a filter it reduces those aliased signals and the IMD results of those drop out getting rid of the hashy looking noise floor.
pma
Prague
Quite high density of the spurious products, to be IMD with mirrors, don't you think?
There are multiple tones combining so you are going to get plenty of interactions between them.
manisandher
manisandher
All the spikes are spaced exactly 100Hz apart, so it's certainly IMD. Thanks.
Edit:
But can you really use "imaging" and "aliasing" interchangeably?
Mani.
Mnyb
Sweden, Västerås
+1
And imho thats why one always should reduce ultrasonic garbage out of a DAC . This IMD circus probably repeats in the preamp and power amp to if your unlucky and maybe in a transducers to if enough of it gets trough.
Wonder how an output transformer on a tube amp reacts ?
manisandher
manisandher
Thanks everyone. I've learned something today :).
Mani.
pma
Prague
If the lines are equally 100 Hz spaced, I doubt it is IMD.
manisandher
manisandher
The 22nd harmonic lies at 22000Hz. The first image of this beyond Nyquist is at 22100Hz. The difference is 100Hz.
It's definitely IMD :).
Mani.
DonH56
Monument, CO
Aliasing usually refers to frequencies above Fs/2 being "folded" or aliased into baseband. Imaging refers to signals that are repeated at multiples of Fs. Aliasing is usually a problem for ADCs; imaging occurs at the output of DACs.
Aliasing: https://www.audiosciencereview.com/forum/index.php?threads/digital-audio-aliasing.1920/
Imaging is shown in this thread: https://www.audiosciencereview.com/...ital-audio-converters-dacs-fundamentals.1927/
Basic sampling intro: https://www.audiosciencereview.com/forum/index.php?threads/digital-audio-sampling-101.1919/
Jitter 1 and 2: https://www.audiosciencereview.com/forum/index.php?threads/digital-audio-jitter-fundamentals.1922/ https://www.audiosciencereview.com/...igital-audio-jitter-fundamentals-part-2.1926/
Delta-sigma converters: https://www.audiosciencereview.com/...igma-delta-digital-audio-converters-dac.1928/
Distortion:
Given two tones f1 and f2 we can state where distortion terms will lie:
  • Harmonic distortion (HD) terms at 2*f1, 3*f1, 4*f1, ... and 2*f2, 3*f2, 4*f2, ...
  • Second-order intermodulation distortion terms at abs(f1+f2, f1-f2)
  • Third-order intermodulation distortion terms at abs(f1+2*f2, f1-2*f2, 2*f1+f2, 2*f1-f2)
  • where abs(x) = absolute value of x
For two tones that peak at the same level the second-order IMD distortion will be 6.021 dB higher than the second-order HD. The third-order IMD will be 9.542 dB higher than the third-order HD. The derivation is straight-forward but messy. I keep meaning to write it up but it's boring.
Distortion terms above Nyquist (Fs/2) will be aliased by an ADC and produce images from a DAC.
HTH - Don
