Good to hear positive feedback on the PA-1's. Really curious about those. But I'd really like to see some measurements before I bring home a pair. Yeah it's just module with wires but that's what I like about it. I can't solder if it meant saving my life.
I hope it also measures like wire with gain. I mean if it's clean beyond the audible range then it's good enough. In the meantime, I'd settle for more subjective impressions, user experiences and observations (i.e. does it hiss?) if you have any more to share.
Since you are okay with subjective impressions. I've heard most of Emotiva's older line and a good bit of the current line in terms of amps dacs and processors.
The most obvious thing about the PA-1 is that they are super lightweight but also fully balanced monoblocks and yet sounded near in sound to my 70 pound class A biased fully balanced monoblocks. Right there tells you what you need to know imo.
In use they had no discernable hiss. The best amp I've heard has been the XPA-1 gen 2 which is at a different level from almost all other amps I've heard. The PA-1 was pretty much at its level, just short by a hair. Where it was just a hair short was that in terms of bass and lower mid range heft the XPA-1's are just monsters at it.
Either way the PA-1 definitely did bass and heft, just not quite at the same amount. I think of it like an XPA-1 with a lighter airier sound.
Where the PA-1 excelled over other amps I'd heard was in terms of dynamics and a sense of speed. They were very quick and had an extended open treble. Which meant I was hearing all the details including the dimensions of the room recording. The only other amp I've heard reproduce dimensions of the room was the XPA-1 (and also the bas-x a-100 in headphone mode only).
This extends to the bass which was very clean, you were hearing the texture of the bass instruments rather than one note bass etc.
Every amp has some sort of tonal sound signature even if it's very mild. The PA-1's tone is tilted towards the treble which is slightly tipped up (still a very natural sound). The XPA-1's tone is tilted slightly towards the bass.
At its price, imo it's a no-brainer in subjective use. Sounds fantastic. If I wanted to I could buy four PA-1's and bi amp my speakers with monoblocks and still spend less than my XPA-1's and those four would take up the space of just half of one XPA-1 amp - if that. Now that's value imo.
I don't know the longevity of the switching PS but since it has been used in other designs for a good amount of time, I assumed it's pretty solid. In terms of measurements, I doubt it measures that well because Emotiva mentioned it's not a measurement king. There's better measuring amps out there.
