that's excellent to hear. look forward your thoughtsI used D03 before. And now I'm testing it against A30a and A300/AO200.
The SMSL VMV A2 and Sabaj A30a are identical products with a few exceptions.
Me too!!that's excellent to hear. look forward your thoughts
I would also like to buy a smsl a300 instead of my Aiyima D03 because of its too small display , but I don't know if it's a good idea, is the A300 as good sounding ? I am hesitating, I am waiting for the opinion of someone who has tested both !!!I used D03 before. And now I'm testing it against A30a and A300/AO200.
Do you happen to have any experience with the Aiyima D05?I used D03 before. And now I'm testing it against A30a and A300/AO200.
Almost everywhere I read that the D03 was better than the D05, but I never tested the D05 !!!Do you happen to have any experience with the Aiyima D05?
Seems to be very similar to the D03?
But the USB DAC does not use the Saber, but RealtekI am currently using a Loxjie A30 (USB input) in my office rig and looking for an upgrade in terms of power
Sound quality shall not be inferior though (SINAD, etc)
I do not want to use two devices (separate DAC and amp)
Apparently the SMSL A300 would not be a good alternative...
The Aiyima D03 seems to be good but I cannot find any measurements
Loxjie A30 Amplifier Review
I do not see your problem. Do you not like USB? Converting USB to TOSLINK does not improve quality anywhere. It removes the host's ability to get feedback from the DAC. The iPad would not know what it was talking to is you ran to a switch. It's that currently on the Loxjie A30 some of the...www.audiosciencereview.com
USB has its own Realtek DAC, BT is from Qualcomm - the one built into QCC, the rest of the inputs work with the Sabre.
You will get the best quality from it by connecting a PC with a loxi digital cable - either optics or coaxial, because then you will be using the best DAC built into this box. After USB, it is a bit worse - but still better than motherboard integrateds.
If possible, try to connect it with an optical cable. Avoid connecting USB and BT as much as possibleWoooow! Thank you @titilandus this is really interesting!
I was not aware that the Loxjie A30 has two DAC chips.....
I will certainly try the optical input
What do you mean by 'loxi digital cable'?
Thank you
The D05 seems to be a higher model of the D03, but it is actually an older model than the D03. You can tell by looking at the IC chips and specs used.Almost everywhere I read that the D03 was better than the D05, but I never tested the D05 !!!
Please don't be too happy.Woooow! Thank you @titilandus this is really interesting!
Thank you
Exactly, there are plenty of inexpensive DACS to be had that will peform perfectly fine for the majoty of people.at the expense of an outdated BT dac... which is fair... just buy a good dac.
This video is a little weird.I just found this video of SMSL A300 which speaks about the BTL connection and which shows how to make this connection at the end of the video, if it can help someone !!!
No idea I don't know anything about this connection system, I just posted it for those who might be interested !!!This video is a little weird.
In the master & slave method, the output of BTL-R is adjusted to the volume level of 40 on the master side and output.
If the slave side that inputs the BTL-R signal is also set to the same volume level of 40, the volume will be further reduced and the balance will be completely lost.
Therefore, in the case of the master & slave method, the volume on the slave side must always be set to the maximum, otherwise it will not be at the same level as the volume on the master side.
In dual monaural mode, the two units are set to the same volume like a video image.
Is the video image just a production?
Forget that video/channel as it is useless ... it is done by a vendor (from Vietnam apparently) that sells both to local/by mail I believe. Avoid that shop by all means. Saw your posts and the reply from that vendor/video owner which of course does not answer your questions at all. Not professional imo.This video is a little weird.
Thank you for the information about the Youtube video.Forget that video/channel as it is useless ... it is done by a vendor (from Vietnam apparently) that sells both to local/by mail I believe. Avoid that shop by all means. Saw your posts and the reply from that vendor/video owner which of course does not answer your questions at all. Not professional imo.
The video showed of course the volume on both unit to be 40 ... if they want to sell the gears. That does not mean the volume is balanced at all ... no one can tell unless you are inside the room when the video is shot and you can inspect how the source/hardware are setup/configured.
Back to the A300. I believe the only info. from this thread reported is that the right channel is about 6 volume steps down in volume compared to the left channel. Not the case you mentioned that he needs to raise the right channel volume to max to balance BTL mode volume (in master-slave mode I mean). And it is only reported once.
There was another report earlier (CA1075) that said the volume mismatch only occurred in direct-BTL mode and it is fixed by going to the master-slave mode. Go figured. Too bad he never posted again and confirm this again so I will not trust that report to be true.
Could you please try to test your 2 units in both BTL mode if possible so we know if you also have this problem?? I take it you have not confirmed this yourself yet. Thanks.
