New mysterious Genelec monitors
srrxr71
Strange thing is that the amps are electrically rated way lower:
So capacitance takes care of the peaks?
I don’t see how else.
dedobot
Sofia, Bulgaria
I don’t think it upmixes at all. I may be wrong. The content has to be created in atmos and then it can be down mixed to stereo.
Easiest way to try is a pair of HomePods.
I'm imagining something (stupid) like a left channel through each speaker from front to back, same for the right channel . The ceiling in mono. More SPL to FR and FL speakers less for the rest.
srrxr71
I see. You mean to create a home made upmixer?
The one I have some familiarity with is old school matrixing. Which is basically what the original Dolby surround and Pro Logic did.
It wouldn’t hurt to acquire some old Dolby pro logic unit for experimentation.
I’ve seen them as low as $50 at used audio stores. Which I suppose don’t exist anymore. I hope decibel audio in Chicago still exists. I picked up some cool good oldies there.
Then I would send that “rear” signal to all those extra speaker positions and also play with their positions.
It’s worth experimenting with.
Also you can do matrixing for free by just playing with the wiring. There are diagrams out there for that. Just do it at the low level before the amps to be safe.
Basically what you are doing is separating what is common between left and right and and what is different.
So that common signal could be better than mono on the ceiling. The difference signal can be placed anywhere all over to provide ambience.
Pretty much you end up with L R sum and difference signals. Which you can place as you see fit.
ernestcarl
I just found this: https://studylib.net/doc/18510796/stereo-shuffling--new-approach-–-old-technique
Very complicated. What exactly does it do? Does it require additional speakers from the L+R or does simulate ambience from the L+R pair?
About the phase shuffler... there's an extensive thread that covers the topic at diyAudio here:
It just enhances the phantom center at playback if one doesn't have a center channel speaker to begin with.
For those who already use FIR convolution, two simple presets can be applied additionally to (only) the left and right channels:
To improve matching of voicing individually between left, right and phantom center even further, we can also apply EQ to the center mix exclusively -- or all channels -- well, whatever subjectively works/sounds best.
"Dullness" of the phantom center voicing (in contrast to the left and right mains) is much more evident in rooms where a lot of acoustic absorption is applied -- i.e. very dry rooms.
As to stereo upmixing into multichannel, it's briefly discussed in this thread: https://www.audiosciencereview.com/forum/index.php?threads/acoustics-service-at-kvålsvoll-design.42899/post-1587149
sarumbear
Speaking of Atmos , I wonder how the stereo music sounds thru Atmos installation ?
Same as it’s played with just two speakers.
srrxr71
A lot to read. I suspected this was related to to problem Bacch-SP tries to solve.
Basically that we have a nose that blocks some beneficial crosstalk at 700Hz+
I need to read up on it again. I remember one of the “solutions” was to place a baffle between left and right ears. I’m confused about why that works. Maybe it blocks cancellations due to the nose?
Anyway I tried it once by placing a thick bass absorber in front my nose. I didn’t notice much difference.
However I have coaxials aimed pretty much at my nose so maybe that helps.
I too have a very dry room and I made it that way with a lot of bass panels. I like it.
I’ll try this again and see if I notice any timbral differences as that signal travels left to right.
ernestcarl
I dunno... placement and angling of the speakers probably also contributes to the "severity" of the dulling/darkening effect on (phantom centered) dialogue/vocals.
According to F. Toole:
"Anyone claiming that a phantom center image is superior to a real center loudspeaker has some persuading to do. The phantom-image situation is significantly muddled, and most listening situations are not perfectly symmetrical. As we will see later, eliminating all of the reflections does not solve the fundamental problem with the phantom center; in fact it makes it worse."
To test for voicing changes, I extract and isolate vocal only recordings and re-route or solo them while quckly alternating (via switching presets) between left, right and phantom center repeatedly. At least in two of my setups (coaxials and traditional two-ways), the timbral difference between phantom and mains is rather obvious.
srrxr71
I’ll give it a try. I’ve done some rudimentary testing and didn’t find anything alarming.
I can mono via both (phantom) or one speaker but i have to turn my head to hear the real mono signal.
I almost don’t want to know about this problem. Keep my head in the sand. But I’ll check.
srrxr71
Pearljam5000
Pearljam5000
The fact that they have 5 midrange drivers
Does it mean the sound will be midrange heavy ?or the mids would be too forward like ATC? :)
Pearljam5000
Pearljam5000
Instead of trying to find questions just post "say something,I need my fix".
We will understand.
Lol
No
But that's not the case
I'm just not ashamed to ask stuff that could sound stupid
because that's the only way to learn
dedobot
Sofia, Bulgaria
Would this be the easiest and cheapest way to try?
I was thinking of lot more simple processing. Stereo/mono channels redirection to certain speakers with SPL correction and may be a pan corrections . No content rendering. , no 3D sound field. Avid ..I had to deal at daily basis with the Media Composer stations at the IT support role. it's everything but easy and cheap.
My question was dull and derailing the thread, please excuse me.
Axo1989
Sydney
I found it interesting that those four domes apparently cover 150/250-500 Hz (the low crossover frequency is variable) so really mid/upper-bass to lower midrange (the way I usually think about it at least). In other words, a lower range than I expected.
goat76
Most ATC speakers are not "midrange heavy", just the old version of SCM19 that Amir did measure a while ago. That one is the odd one out, don't spread a myth created by some members at this forum. :)
