I think in this case, beauty is in the eye of the wallet-holderIf you can’t differentiate by sound / engineering, I guess the designer will have to do it.
Indeed ugly as hell, but beauty is in the sight of the beholder I guess.
Yes I do think you should listen and unsighted as ypu ho;d a groundless bias against an innovative transducer that appears is used in cost no object loudspeakers as well as professional monitors.Long story short, the AMT was commercialized when the dome tweeter wasn't yet used on a regular basis as the quasi standard. Early models of domes had problems and sported peculiar solutions, e/g KEF's T52. Think of a parallel development of the AMT and the dome to solve the same problem (my claim basically), and the dome won. The AMT btw had the very problem to be both impractical and expensive beyond imagination, the ESS namely.
There is no compression (the other compression) taking place, as is often suggested by the name. No transformation, no benefit. This makes me think of this flagship speaker's opposing bass drivers. Still no compression, hence no gain.
You're serious, I should listen? Unsighted because of science? AMT is a marketing ploy. Adam does an exceptionally good job nevertheless: https://www.audiosciencereview.com/...adam-a5x-review-powered-studio-monitor.22860/
No traces of exaggerated higher order distortion, because the AMT is crossed over quite high by dome tweeter standards. Still the vertical dispersion is at least 'good'. Benefit of the AMT, any? My answer is still: "none". (Especially when compared to what a waveguided dome could do.)
Most any reputable manufacturer shows the same--once you get well beyond the noodle flapping band, they settle down to superb levels of distortion. More about the tech here.99.99% of the AMT diaphragm area moves.
Get your hand on good AMT - like Beyma TPL-200.
I measured vanishingly low distortion, crossed over at 1200 Hz.
I don't understand the bold part, please explain.Most any reputable manufacturer shows the same--once you get well beyond the noodle flapping band, they settle down to superb levels of distortion. More about the tech here.
I think they're handsome. Could never afford a pair, though.The white looks a bit gaudy, but the black one is inoffensive, just different, and I actually have to say I like the green finish: View attachment 283441
Not what I'd spend that kinda money on, but hey.
I think it might be Welsh![]()
Monitor Audio's Hyphn Flagship Loudspeaker Is Unlike Anything You Have Seen So Far
Monitor Audio makes a statement with new Hyphn loudspeaker for $92,500. Will more speakers look like this?www.ecoustics.com
Interesting design. You'd think for that kind of money they could afford a vowel.
https://en.wikipedia.org/wiki/HyphenHYPHEN ... noun ... the sign -, used to join words to indicate that they have a combined meaning or that they are linked in the grammar of a sentence (as in a pick-me-up, rock-forming minerals ), to indicate the division of a word at the end of a line, or to indicate a missing element (as in short- and long-term ).
Wow these are not small cracks... Bit strange, with custom crates, must have been dropped sideways, where the bottom of both pillars were compressed together, breaking at the connection point. Probably had material between the pillars, but I guess not correct material as was likely not solid enough to withstand the hit, must have been a decent bump or fall!There’s a damaged pair in Toronto up for auction for insurance salvage…
Doesnt seem too bad tbh if it was an active design it might be even better, but weird dip in the upper bass, and surprisingly not a ton of extension despite its claims about the force canceling woofers, id like to know what the spin data would look like for polar mapSome more measurements:
Source: https://audio.com.pl/testy/stereo/kolumny-glosnikowe/3842-monitor-audio-hyphn#laboratory
How can you tell?They sound pretty good
