- Thread Starter
- #21
@Ilkless @thewas_
I think those are both good candidates, but yeah my money is primarily on the inverted dome tweeter.
I've asked Focal about why they don't use waveguides(or at least larger ones) before and their answer was basically that the inverted dome gives them the directivity control they want without leading to narrower dispersion (don't quote me on that, but it's the basic premise). So as apparent from the measurements, they seem to prioritize wide horizontal directivity over some other details like vertical directivity or perfectly smooth on axis.
I'm not sure diffraction has too much to do with it on the higher end models, as the cabinets are quite radiused. and on the lower end models you'll note the Chora and Aria actually have very shallow waveguides, probably also to minimize edge diffeqction rather than for directivity controls(esp on the chora with its super sharp edges).
They're some of the relatively few speakers with such wide directivity out to 9-10kHz which definitely appeals to my sensibilities, but as with everything it comes with some compromises
