so i just spent a few hours in the store's listening room with a set of 8040s and the 8030s. conclusions: at the upper midrange and upper ranges, you literally can't tell the difference between the two. that's incredibly impressive on genelec's part. also, C on the A-B-C switch was a set of focal trio6 Be's. in the tweeter ranges, the genelecs did well.
anyway, we threw a 7050 on the 8030s to listen against the 8040s and i still preferred the midrange and bass extension of the 8040s, so yah i'm going for the 8040s. deciding whether to keep the SVS sub with them or stick to near field. borrowing the store's 8040s until the new ones come in
40 filters in REW later (keep in mind the poor mic response is 10% room artifacts and 90% lack of a umik), i'm getting the following
https://www.dropbox.com/s/3y8g8eayexrvela/Screen Shot 2021-04-06 at 8.33.29 PM.png?dl=0
green is with the sub, orange is without. the low sub volume levels are an artifact of non-linear volume oddness between the dac balanced and unbalanced outs that require the sub volume and monitor sensitivities to be mucked with by hand, but there's plenty of shaking of the desk in the subbass, so i'm reasonably happy there. i'd like to ditch the sub and go completely nearfield though, so i think i'm going to try some filtering of the low end of the monitors alone to compensate for the poor placement of the rear ports.
