estimated in room response is a far field prediction. You won't be listening to KH 150's from far field.
-While sitting very close to speakers(*close* in this context depends on speakers and how the drivers sum up), 2 factors determine the tonality & tonal balance:
Sum of early reflections PLUS direct sound.
As you get farther from speakers, sound power response of speakers start influencing tonal balance more and more. That's why Estimated in room response consists of
44% direct sound, 44% early reflections, 12% sound power. Estimated in room responses do not give much idea about how nearfield speakers perform unless you'll be sitting very far to speakers which is not what they are designed for! (and the magnitude of how much sound power influences the tonal balance depends on listeners distance to speakers, that 12% is going to be higher if you are sitting in a completely reverberant field where direct sound can't have an influence)
-To wrap up, if you are sitting in a reverberant field(far from speakers),
Sum of early reflections PLUS sound power PLUS direct sound determine tonal balance.
Depending on your distance to speakers the influence of sound power in perceived tonal balance changes. Far field estimation is basically a very rough estimation of how speakers should sound from afar.
I see people keep checking far field responses of nearfield speakers which they listened from nearfield. That is so pointless.
So why do Neumann speakers -usually- sound darker?
Because their Early reflections Directivity Index and Sound power Directivity Index is higher than Genelec speakers. Remember, we hear a combination of reflections and direct sound. And how reflections are formed inside a room can be predicted based on the directivity of speakers.
For example:
Even if we EQ KH 420's on-axis to 8361's on-axis response, 8361's will always sound a bit brighter than Neumann KH 420,s because their directivity index in higher frequencies is lower overall.
