Moondrop Chu II IEM Review
Rate this IEM:
    Votes: 2 0.8%
    Votes: 6 2.3%
    Votes: 36 13.6%
    Votes: 220 83.3%
For consumer-oriented solutions, amongst others, I have in-depth experience with Mini, which relates to ...
"(B) Same with the 10kHz trough, which is told to be a must btw, and the 14kHz something peak, again a must."
Do you have hard evidence in general for that, or in particular in an IEM?
Thanks for the link, I'm looking forward to give it a try.
On the question, there are personal HRTFs for diffuse field, and I've seen those dips and peaks all the time. B&K published a paper on the acoustic impedance of the ear canal which shows the resonances clearly. Hence they must be seen in measurements of an IEM put onto the canal.
If we consider HRTFs as part of the physiology, I’ve had mine measured multiple times and even programmed a DSP with it for spatial audio.
That's a whole new discussion I won’t get into but on the consumer side, Idun is a solid option.
Sure, something like Idun may provide a solution. Mimi not that likely. I gave up on the latter, especially as it seem to address wide band hearing loss rather than fine grained specifics of a personal HRTF. The former is costly, if regularly available at all, and is clearly not considered when evaluating the Harman preference.
It's only anecdotal, but I tried to optimize my headphone experience with extra equalizing beyond just linearizing to whatever standard. Seems I prefer some extra dip at 10kHz on top of the headphone's a lot. Due to age I cannot comment on my preference above 12kHz. To me the sounds up there don't appear as an exact tone no more. At around the 3kHz bump I shift it a bit lower, tune it less pronounced and narrower.
In the end I'm not critizising. It is more curiosity, namely why the regular Joe doesn't feel the difference between the Harman preference opti versus a personalized fit. Seems it is less of an issue, because otherwise knowledgeable people would eagerly equalize accordingly. Conversely, if some deviation is readily acceptable, why so picky regarding the match to Harman? It all wonders me.
I EQ a lot… But I don’t think I have settled on a “personalized fit”:
1/ I easily get accustomed to a HP/IEM sound as long as it’s reasonably good.
2/ When EQ’ing, I usually end up with the following: I can hear the impact of a particular EQ filter… but, because of 1/, I’m not sure and can’t really say if it sounds “better”.
I’m most likely in the Harman “taste zone” referenced by @Maiky76 in their previous post, but I like the precise, picky, EQ to the Harman target as an anchor of what “good sound” sounds like for most—the highest preference score.
2/ When EQ’ing, I usually end up with the following: I can hear the impact of a particular EQ filter… but, because of 1/, im not sure and can’t really say if it sounds “better”.
Thanks for picking this topic up and sharing your personal experience. It goes a bit beyond some commentary on a particular IEM. And sure enough, I seem to like the Harman also, but still I'm curious about further improvement. The how-to is the problem as long as I cannot identify my preferences (sic!) for one, and second the combinatorial explosion of all the possibilies considering their mutual dependencies. CU
Agreed on the difficulty of the "how-to"! I like @Maiky76 and Amir approach to limit the number of filters--3 or 4 filters that I can "evaluate" individually: what is the audible effect of filter #1? Do I seem to prefer the resulting sound? What about "exploring around" (varying freq., gain, Q-factor)? If an IEM has some significant deviation from the Harman target as-is, is there anything I like in the FR?
Another interesting tool that could help with the "how-to" is MSEB, HiBy's "pre-baked, typical, PEQ filters" (see @Jeromeof MSEB EQ measurements in his R1 review at https://www.pragmaticaudio.com/reviews/2025/02/hiby-r1/). What MSEB does is to provide basic "words" that could be used to characterize a PEQ correction or the HP/IEM FR curve as compared to the target. One could express his/her preferences against the Harman target in unified "MSEB language", for example,: I like a "2dB warm temperature tilt, a -1.5dB vocal recessed, and +3dB air crisp" over the Harman target.
Warning: Totally uneducated, unempyrical and subjective impression on the Chu II...
Got the Chu II 2 weeks ago and had it for a few days before I returned it......too peaky for me and not enough bass (I tried different ear tips to no avail) .
I received the week after the Ziigaat Nuo -after viewing tons of Squiglink curves- and to me it corrects everything I didn't like about the Chu II. More bass extension, still a bit peaky on the 10-12 kHz (but less), louder, and reacts very well to eq.
I may be a bass head and not even be aware of it -I'm a total noob to iem addiction syndrome- , so I am waiting for a Kz Castor Pro Bass and a Kinera Celest Wyvern Abyss, curious about what s basshead iem is....
Hello there,
I have found this wonderful forum a couple months ago, and i have decided to join here rn..
I was not really aware of this iem revolution going on untill just a few months ago when i found individual threads on this site on iems and i was taken a back by
these thourough and extensive analyses.
And so.. i have decided to buy the only one on my local market that that got here a very high rating and that is moondrop chu 2.
I am used to listening music on speakers and headphones, i am suprised by the amount of clarity and detail here , but they are pretty harsh and sibillant.
ouch.
I get fatigued very fast with them , 15 minutes and i am out. i will try to eq them. I got Peace Apo eq, i tried some of these harman curve presets in Peace Apo and it's still harsh, i will try to wrestle myself with some of the frequencies a bit more, it is still too harsh and textures are bit of..plastic and metalic. and midrange is empty. but bass is really good!
I would like it to be more.. hm.. warmer, and that sounds have some more weight to them if that makes sense. lushness,
but i hope that i will find some balance, if not on this iem, perhaps there is some more adequate for me out there.
PS AND Truthear Hexa just arrived to the local retailer where i bought chu 2!
I hope to get that one in near future , since i produce music a bit.. it should be more suitable for music production and mixing, or so i have heard?!
Well, anyways. Thanks for everything!
have a nice day
cheers
Hello there,
ouch.
have a nice day
cheers
It's strange that there are “sharp" comments about the Chu2. I compared it with the DT900Pro, HD660s, HD600, and K701. No matter how I listened, the Chu2 couldn't be as sharp as the DT900Pro. Among the headphones I use, it is definitely a warm headphone
Made mine wireless (w/ TRN bt20 pro adapters). Works very well. Case is humongous though, but they have 13 hours battery life outside the case. I like this style because if they work themselves out of my ear they don’t fall out
Only problem is you are limited to AAC and SBC. I’d take SBC over AAC (or aptX) but I don’t think there is a way to choose. A little surprising aptX is not supported. LDAC just isn’t available widely enough so I’m not surprised it is not supported.
I mean I use an iPhone anyways
These are freaking amazing for the price.
I'm using them with foam tips by SONICFOAM.
Wow. I didn't know this adaptor existed. If I could use these wirelessly....would I ever need anything else? :oops:
I checked out Amazon. There are complaints about signal breakup, poor range, and the charging connection in the case. I'd be curious to hear if you've had issues like these...
