7Hertz Timeless IEM Review
Rate this IEM:
    Votes: 18 16.5%
    Votes: 53 48.6%
    Votes: 31 28.4%
    Votes: 7 6.4%
This is a review, listening tests, EQ and detailed measurements of 7Hertz (Hz) Timeless planar driver IEM. It was kindly sent to me by a member and is on sale right now for US $176 (normal $220).
As you see, the same is unique as is the construction made out of machined aluminum. I thought this would be an issue but wearing them was very comfortable for me. I performed my testing using the tips you see. Two boxes are provided, one for a different shape than the other. IEMs are stored in a solid, metal box that is not pocket friendly but would stand driving your car over!
If you are not familiar with my headphone measurements, I highly recommend to watch my tutorial on it:
[And subscribe to the channel :) ]
Timeless 7 Hertz IEM Measurements
As usual, we start with our IEM frequency response measurements using GRAS 45CA as a fixture:
At high level, this is very good compliance with our target. There are small variations especially the pulled down area around 3.5 kHz which we have to evaluate using listening tests.
Relative difference to our target as a result, only shows small variations:
Linsoul 7HZ Timeless in Ear Monitor reltive target frequency response measurement.png
What was shockingly disappointing was the distortion in lower to mid treble:
Linsoul 7HZ Timeless in Ear Monitor relative THD Distortion response measurement.png
We have nearly 3% distortion at 1.8 kHz!
The planar panel must be resonating at those frequencies.
Group delay is not revealing of much as IEMs don't suffer from internal reflections like headphones do:
Typical of planar transducers, impedance is on the low side:
I rescaled the vertical axis to show the variations that we observe in frequency response and distortion, showing this is some kind of acoustic event.
Sensitivity is worse than average:
Timeless 7Hz IEM Listening Tests and Equalization
I am migrating my Roon server to another platform so temporarily don't have access to my usual test tracks. Using what I had, I found out of box tonality to be very good. I did try to two corrections though:
Band 2 opens the sound up a bit -- as it usually does in headphones and IEMs. Spatial qualities went from good to very good. Band 1 took a way a bit of boominess especially before I reduced its negative gain. In balance, I found the two filters to benefit most of the tracks I threw at it. But on one of my bass and treble heavy tracks, I found the sound to become brighter than I liked. I would say then that the deviations are within degrees of error in the research target.
With or without EQ, sub-bass performance was excellent owing to nice boost in low frequency response.
The tonality of 7 Hertz IEM lands slightly outside of our target. Per listening test remarks, we simply don't have accurate enough target to say this is bad or good. The high level picture of good amount of bass response is certainly good. Overall then, I have no complaints about the tonality. The issue is that of distortion. Sometimes I feel that I am the only one running distortion tests and identifying clear engineering issues that could have been resolved had there been any focus on it. Yes, the distortion response doesn't immediately tell you what audible issues you may have. But it does tell you that all else being equal, you want an IEM/headhphone that doesn't have copious amount of distortion, especially where our hearing is most sensitive.
Putting it all together, I will recommend the Timeless 7Hz IEM for its tonality, comfort and unique look. Distortion keeps me from highly recommending it.
Reserved for @AdamG to kindly post the specs (if there are any).
Manufacturer Specifications:
Was the distortion noticeable and / or bothersome in the listening test?
Edit: P.S. Thanks for yet another great review.
I found that once I put these IEM's fully into my ear, and then slowly pull them out a MM or so, the bass drasically improved. I'm using dekoni pads, and powered with a Schit dac amp. I normally send back IEM's, but these have been really solid for me. I'm keeping them!!
It is very hard to know for sure without highly controlled testing. it certainly was not excessive enough to be bothersome.
I owned them 4 years ago, quite enjoyed the bass on them but I had eq from 1.5khz and up to tame them down as I found them very shouty.
Great review for a unit that has it's place in the history of recent iems boom.
That distortion peak is really ugly, DD iems have spoiled us too much nowadays.
Thank you to Amir and to the owner!
These are mine. I was quite happy with the unEQed sound. Glad to see they measured fairly well. The distortion and 3.5kHz trough look a little troubling. In use I find them very pleasing. I have yet to figure out how to incorporate EQ on my iPhone 15 Pro Max that I use these with; I think I'll spend some more time on that. I liked the sound of the OG Timeless so much that I also purchased the AE and II versions which I'll also be sending to @amirm. It will be interesting to see how they compare. They remind me of the tonality of my Audeze LCD-3 headphones which I quite like.
Martin
Not a bad IEM, but the same company sells an IEM that's a tenth of the cost of this one (at normal pricing) that has both better compliance to our target curve and much better distortion performance in the 7Hz Salnotes Zero: https://www.audiosciencereview.com/forum/index.php?threads/7hz-salnotes-zero-iem-review.50226/
I had a pair of the similarly measuring 7Hz x Crinacle Zero:2 that I found oddly unsatisfying. I find the Timeless much more pleasing to my ears.
Martin
I find that these earlier planar iems that followed the Timeless had noticeable "grungy" mids that probably conformed their FR, with that weird 2khz peak (most of them have it) and "ragged" upper mids. It was more noticeable with the S12, which inspired me to make a whole Tidal playlist for them. But take it with a grain of salt because it's a personal hypothesis not immune to confirmation bias.
IME they don't take well to EQ and have that "love it or hate it" energetic profile, with elevated bass and treble and that "misplaced" 2khz peak that offers a different (coloured) take on pinna reconstruction.
I have the Timeless AE, which has even more bass and upper treble, and I quite like it for a V shaped iem. I wouldn't say that, today, it's worth the price I paid though.
I can't conceive of a world where higher distortion lends itself to better sound. For me, high measured distortion is always a deal breaker. And IDK, what benefit is conveyed by planar driver, or, for that matter, name brand drivers which some internet jockeys absolutely insist makes a dramatic difference. As always, they can never show that in the FR, and they have no measure of distortion or dynamic range or even group delay to back up their claims.
But they have plenty of smug certainty.
Thanks @amirm . Just a point about he EQ: you mention that Band 1 reduces boominess when it is a dip at 1.8 kHz. Typo?
The frequency is not a typo. But my description might be. :)
I considered whether it might be a perceptually relative thing, e.g. reducing the 1.8 kHz peak by too much made the boominess more noticeable.
What would cause the distortion to rise so precipitously above 1kHz? Seems the reverse of what we normally see with higher distortion in lower frequencies.
Are there multiple drivers in this IEM, with one behaving much worse than the other? Is this a problem with planar drivers? I'm so confused!
It is the membrane resonating at multiple frequencies I think. It is basically a sheet of mylar with copper traces in it so if not designed well, will have various modes.
