Monitor2USB Help
egothrasher
I am currently running the smsl su8 DAC. I have that plugged into my PC via usb. I then have the monitor2usb connected to that via balanced cables to the monitor2usb input 1. From the monitor2usb, I have my two monitors connected to monitor A output. I then have monitor C, the mono channel connected to my subwoofer.
Thing is though, even at max volume, my sub is very low. This is with the DAC maxed out in volume. If I were to plug my sub directly from the DAC, it would be probably be 5-10x louder than it is currently through the monitor2usb.
Any and all help appreciated.
