Monacor Sound-4BT Spinorama measurements (CTA-2034)
Ageve
Sweden
Here are some measurements of Monacor Sound-4BT.
It's a powered bookshelf speaker manufactured by Vistron (Dong Guan) Audio Equipment.
A slightly modified version is sold in Sweden, by "Intelligent Sound" (IS Monitor 4e). You've probably never heard of them, but it's a controversial manufacturer, claiming that the only thing that matters in a speaker is the crossover. Thus, they take inexpensive/bad speakers, replace the crossover with a secret one (hidden in epoxy glue) and sell them at 5x the price (or more).
Anyway, the speaker tested here is the original version. I measured the passive/right speaker, connected to the powered one.
My measurements are quasi-anechoic, with near-field port+woofer, combined and corrected for baffle edge diffraction, merged with gated outdoor measurements at 1m distance (5ms window).
A massive port/cabinet resonance and uneven woofer response. The tweeter peak at 9 kHz can also be seen in the 1m measurements (resonance or breakup).
Horizontal directivity:
0-90 deg for comparison with Stereophile measurements:
Vertical directivity:
Distortion:
I don't know why, but distortion at ~500 Hz - 4 kHz is lower at 90 dB SPL, while bass distortion is much higher (as expected). I measured three times (and the results above are with another power amplifier), but it made no difference. The mic was not clipping.
Here's a zoomed out view. 200% distortion at 50Hz. ;)
I have attached a recording of the bass distortion. It's a combination of port noise and woofer distortion. The volume was low, and the woofer wasn't bottoming out.
It wasn't bottoming out during the distortion measurement either, but the port made a lot of noise.
The speaker isn't broken, and it hasn't been abused. It was just as bad when it was new. ;)
My thoughts:
Thanks @Ageve for another speaker measurement!
With a small EQ, the speaker may get better esp. at low level: the score increased from 3.7 to 5.7. Note that this is an anechoic measurement and that you will still need to tame the bass in your room.
Code:
         SPK auEQ
NBD  ON 0.49 0.38
NBD  LW 0.47 0.33
NBD PIR 0.47 0.34
SM  PIR 0.50 0.89
SM   SP 0.73 0.92
LFX       56   44
LFQ     0.94 0.94
Score    3.7  5.7
w/sub    6.2  7.8
Histograms show progress on all curves:
