Biltema 84-1511 BT-speaker Spinorama measurements (CTA-2034)
What are your thoughts about this speaker?
  • Very good
    Votes: 12 57.1%
  • Above average
    Votes: 1 4.8%
  • It's ok
    Votes: 3 14.3%
  • Below average
    Votes: 2 9.5%
  • Poor
    Votes: 3 14.3%
Ageve
Sweden
Here are some measurements of a Biltema 84-1511 Bluetooth speaker.
The current price in Sweden is 129 SEK (~12.9 USD).
Biltema is like a Swedish mix of Harbor Freight and Canadian Tire, but they only sell products with their own brand name.
The 5m (~16.4 ft) 3.5mm cable used was 59.90 SEK (~5.99 USD), well above the recommended 10%, and of course it's from Biltema as well, for perfect synergy. I didn't have time to do any cable burn-in though, but it should only affect the subjective performance, since it's not measurable.
To make sure that I was only using clean power during the measurements, both the speaker and my Macbook Pro were running on battery - no chargers connected.
I had to put the speaker on a glass to reduce reflections from the stand, but don't worry. The glass is transparent.
CTA-2034 data:
The 1.6 inch woofer drops off below 400 Hz.
Sound power, early reflections and directivity index are all interesting, most likely because of the up-firing driver.
Vertical 0-deg axis is with the driver at a 90 degree angle, to get the same "on-axis" response as the horizontal 0 deg.
Early reflections:
The very bright ceiling bounce is expected with the up-firing driver. Maybe you could use this speaker for Dolby Atmos?
Estimated in-room response:
Horizontal directivity:
Vertical directivity:
Near-field:
The woofer was distorting (audibly) quite a bit at 72 dB SPL / 1m (82.5 dB @ 30 cm), so I didn't measure at higher SPL.
Obviously bad below 300 Hz, but surprisingly low distortion > 500 Hz.
Listening test:
I started by listening to Eiffel 65 - Blue:
Imagine a large, open and detailed sound, with all veils lifted. It's like you were there at the recording session. Both micro- and macro-dynamics are impressive for a speaker of this size.
I then listened to a number of reference tracks, and I have to say that this little speaker is quite impressive. It needs a subwoofer (or well, a woofer) but imaging is excellent and overall tonality is quite neutral.
Well, that would be very impressive, if it was true.
(The measurements are real though)
Ha ha, Ageve is dripping with irony. :D
I have Biltema's 4 mm/6 Gauge OFC speaker cable, 10 meters for $28, in my HiFi system. They work as they should.
However, I haven't even thought about Biltema's speakers until today. None that I will think about after today either. Good job Ageve.:)
Edit:
If you're interested, I can send you a pair of really small Audio Pro speakers I bought at a flea market for $5. I'm guessing they measure better than these Biltema speakers.;):)
I absolutely love these reviews, I suppose reviewer had fun doing it and that's the whole point.
Thanks Ageve!
I have actually used that song to listen into speakers before.
Come to think of it, I use Biltema "high definition cables" (OFC, 2.5 mm / 10 Gauge) when measuring speakers (well, passive speakers, not this one).
Banana for scale:
Awesome stuff. Bit of EQ and this is great sounding speaker.
Bit of EQ....a lot of irony in this thread.:);)
....Screenshot_2025-04-01_184217.jpg....
Sending a signal that has undergone EQ via Bluetooth, I don't even know how it works in practice. It might work. I haven't tested anything like that. Never mind. IF it would work, that super small amplifier in them would backfire immediately and be driven into clipping. That is if that speaker doesn't have a built-in limiter that makes it impossible. But then it's unlikely that they'll even be pushing out SPL level at a normal listening volume.
Damn how bad it can sound with low-power amps driven into clipping. That in combination with low-power speakers doesn't make it any better. We've all experienced that. Think crappy old car stereos where the volume is turned up. Some small portable boombox, clock radio and so on. :oops:
April fools day -> to the review page immediately! :)
Hahaha, nice review for today.
Actually, it's good to see what a "bottom of the barrel" speaker looks like in these measurements. I'd be curious to see a "good" BT speaker (e.g. JBL Flip or even Go) with the same treatment.
No real output below 300hz is pretty tragic, even for the money. I can say with some confidence that whoever did the sourcing for this didn't bother selecting their supplier based on sound quality. They probably just got the best margin from a certain factory or distributer and went for the whole line.
You can find the same form factor and similar cost with more bass if you just walk around an electronics trade show for 90 minutes, you can finish that job before lunch on day 1.
I'm sure I can buy better BT speakers for around $13.
Creative Muvo Play comes to mind even though its double of $13, but you get the point.
